September 24, 2026, 10:17:32 am
| | |-+  single Setrab on Deano's 67 - Deano can post a clear pic ? :)
Author Topic: single Setrab on Deano's 67 - Deano can post a clear pic ? :)  (Read 6293 times)
pupjoint
« on: June 23, 2014, 02:50:51 am »
hi Deano, if you are reading this, possible to post a close pic of the single Setrab on your 67, if you have of course?  saw the small pic on the Hot VW Feb review, wondering where you got those round clamps from, did you use the Setrab brackets as well?.
thanks in advance!  Grin
Taylor
« Reply #1 on: June 23, 2014, 04:23:55 am »
Not Dean obviously but I mounted mine in the same spot a while back with 2 stainless T-bolt clamps.  The nut tightens and leaves a lot of thread so I put some rubber hose on there, then washer and bolted the Setrab to it with some extra 1/4 28 nuts.  I made a small bracket for the other side and bolted that to the pan.
pupjoint
« Reply #2 on: June 23, 2014, 04:30:57 am »
thanks!
« Reply #3 on: June 23, 2014, 05:08:51 am »
Pics please  Grin
Martin S.
« Reply #4 on: June 28, 2014, 03:29:42 am »
Ya pics please! My single is on the way from Aircooled.net  Cheesy
deano
« Reply #5 on: June 29, 2014, 05:15:27 am »
Cooler mounting brackets came from Foothill.... And clamp on torsion housing.
Anglia Obsolete Guru
'67 Heaven
« Reply #6 on: June 29, 2014, 06:48:36 am »
Any contact info for Foothill?
TIA
marc1951
« Reply #7 on: June 29, 2014, 07:43:48 am »
Simple and cheap pipe clamps work just fine on my Setrap.  Opposite end is attached to Berg trans mount and a bracket  connected to top shock bolt that allows cooler to hang down slightly on an angle to catch the air at speed.  The fan rarely goes on and when it does, it's because the car is standing still.
Marc Buehler
The legendary DRA car club
(Der Rennmeister Association)
Martin S.
« Reply #8 on: July 09, 2014, 04:28:00 am »
Since my old cooler died and had the hoses end near the filter location, I thought I'd try mounting the little Setrab there. There is plenty of room for it, although it could use some kind of a grill. So far it has worked excellent! My drive to work thru city roads (under 60kmh) had the oil temp up to 225 deg F and with the new cooler with same drive it was 185 deg F. Perfect so far.  Smiley
