October 13, 2026, 11:21:14 am
WBX help needed asap...still some more
Topic: WBX help needed asap...still some more (Read 9868 times)
JIMP
June 24, 2014, 16:13:56 pm »
Hello, do you know what is the head channel seal gap of a WBX DF code? Thanks in advance.
Friendly Dimitrios.
Last Edit: July 18, 2014, 08:49:37 am by JIMP
mr horsepower
Re: WBX help needed asap
June 24, 2014, 20:46:19 pm »
3mm my friend
gr henri
JIMP
June 25, 2014, 11:29:24 am »
the 3mm is with or without the cylinder washers? thanks
mr horsepower
June 25, 2014, 17:26:00 pm »
is without the washer thats an extra 1mm
gr henri
JIMP
June 27, 2014, 06:28:03 am »
Ok you're the man! thanks a lot henri
Friendly
Dimitrios
JIMP
Re: WBX help needed asap ..more now
July 18, 2014, 08:20:11 am »
OK some help still needed here..
the above mentioned engine worked OK until now -thanks to Henri for this- and suddenly about a day ago a big quantity of oil escaped in the water, I mean the other way as usual. The water in the oil is barely seen but a big quantity of oil has gone through the entire cooling system. Is there any point besides the sealing surface of the cylinders from where the oil can go the other way? I mean like a crack or something? I really would like to hear some inputs as I need this on the road, is a comercial vehicle that helps me alot..
Friendly
Dimitrios
JIMP
Re: WBX help needed asap...still some more
July 18, 2014, 14:08:57 pm »
Ok this is really weird, I cleaned all the cooling system, started again engine and in some minutes the oil starts to appear again in the coolant, so thi smeans we have a leak on the oil pressure side. By exprinece where there is a potential point of such failure as I cant recall any by memory, I thought that the water jackets are completely irelevant of the oil pressure system, really hoping for some help here, cheers and thanks
Friendly
Dimitrios
mr horsepower
July 19, 2014, 23:20:01 pm »
do you have an heat exchanger on that engine ?
gr henri
JIMP
July 20, 2014, 18:36:20 pm »
Hello
no exhanger, that's the weird..
Friendly
Dimitrios
July 20, 2014, 20:15:50 pm »
I thought WBX had a small oil cooler built-in to the oil filter housing?
# 13 on this diagram........
http://www.vwheritage.com/vw_parts_Oil-System_act_page.render_pageID_674.htm
JIMP
July 21, 2014, 05:49:20 am »
Yes exactly, the bigger engines have that, this one is a df engine, no oil cooler installed on this one..
Friendly
Dimitrios
Jesse Wens
April 12, 2016, 17:43:53 pm »
Quote from: mr horsepower on June 24, 2014, 20:46:19 pm
3mm my friend
gr henri
Just to be sure, this is 3 mm between the waterjacket of the enginecase and the head?
Jesse
fastbus
April 12, 2016, 18:26:20 pm »
You have a green sealing ring that helps seal the head to barrels at the top end of the cylinder liner and a black sealing ring at the base of the barrel thats seals the cylinder liner to the case.
The main gasket where the head meets water jacket does not have any need to seal oil so i would be looking at the way the barrels have been sealed.
The barrel bases need a decent bead of silicon when installing the cylinder wet liners.
Hope this helps
13.66@102mph in my old T3 crew cab builders truck!
13.01@109mph in my bug so far!
