June 10, 2026, 19:52:35 pm
352174 Posts in 28911 Topics by 6920 Members
Latest Member: chris41
| | |-+  Aluminium fuel hose and fittings
Author Topic: Aluminium fuel hose and fittings  (Read 5991 times)
UltraOrange67-2443
« on: July 04, 2014, 14:00:52 pm »
Thinking of running a aluminium fuel hose from my filter (after pump) to Y piece on my EFI system.
Anyone know if the fittings can take the pressure?
The type with a olive and no flare are only rates at 50psi.
Cheers, Nick
1967 1200 2920cc EFI
spoolin70
« Reply #1 on: July 04, 2014, 17:40:05 pm »
Are you talking about aluminium hardline fuel hose ?
Goodridge and Krontec both make some. I've got the Krontec and although I don't know the rating, I've had around 140 psi through mine with no leaks.
Darren
UltraOrange67-2443
« Reply #2 on: July 04, 2014, 21:19:47 pm »
Darren
Hi Darren,
Yes hardline, I've looked at the Russel lines and compression fittings.
I need 1/2" for -8 and 3/8" for -6, Krontec are metric.
Cheers, Nick
spoolin70
« Reply #3 on: July 05, 2014, 07:07:54 am »
Morning
According to this : http://www.interex.co.uk/motorsport/content/assets/Goodridge_Hardline_Cat.pdf ,the working pressure of the aluminium tube is 1375psi. But that's only 8mm bore which would do for the -6.
From memory (I looked into this a while back), 10mm bore for -8 is harder to find.
Darren
Andy Sykes
« Reply #4 on: July 05, 2014, 12:00:18 pm »
Like this
« Last Edit: July 05, 2014, 12:27:11 pm by Andy Sykes » Logged
UltraOrange67-2443
« Reply #5 on: July 05, 2014, 21:42:15 pm »
Morning
Darren
Hi Darren,
Its not the tube but the fittings I'm worried about, some say for low pressure use only.
Fine on a Carb motor but not for EFI.
UltraOrange67-2443
« Reply #6 on: July 05, 2014, 21:44:05 pm »
Like this
Nice job, are they the nut and sleeve type with a 37 degree flare?
Do you know what pressure they are rated at?
Andy Sykes
« Reply #7 on: July 05, 2014, 21:52:00 pm »
Yes nut and sleeve and over 500 psi  so should be fine for fuel pressure lol
spoolin70
« Reply #8 on: July 06, 2014, 00:00:33 am »
Ah yes I understand. Pointless having a 5000psi working pressure line if the fitting is only 5psi rated huh.
Andy - is any of your lovely pipework 10mm bore ? ,or larger ?
Darren
Andy Sykes
« Reply #9 on: July 06, 2014, 08:43:26 am »
An6, an8 and An10
