September 25, 2026, 03:54:24 am
| |-+  For sale!
| | |-+  Parts for 2.4 Water/Oxyboxer
Author Topic: Parts for 2.4 Water/Oxyboxer  (Read 2241 times)
Lightning Grey
« on: July 06, 2014, 08:26:38 am »
Hi guys,
i am offering some parts from a water/oxyboxer project...
1 Case WBX (DG), water jacket removed, lifterbushings cut down 2mm and prepared vor type 1 bushings
1 WBX crank, needs rework on rod pin 3#, 76,4
1 cylinder Deutz, 100 mm bore, cut zu length, cylinder foot milled to 105,9 (new)
1 set Pistons, subaru 2.5 16V, bore 100mm (2nd oversize) with rings, 23mm pin (new)
1 set (2) waterboxer heads, welded to use with aircooled cylinders, bore 106,9mm, double springs, valves 41/36, ( almost as used in limbach 2.4T)
Megasquirt MS 1 (unused)
Throttle bodies, taken from Suzuki GSX-750 R, 40mm, with welded type 1 manifolds, prepared using yamaha stock gaskets between manifold & body, center cable link for levers
double pulley 5 or 6 pk, steel, weight about 5 lb. (handmade. needs to be measured)
asking 1.700 €
optional:
215 Flywheel type 4, lighttened, unused, no bearing
215 HD clutch sachs, pressure plate, disk, used but good
asking 320 €
215 clutch sachs, pressure plate, disk, stock, used but good
asking 90 €
Crower cam type 1, stock wheel included, 298° @.05 intake 260°/outlet 272°, lobe separation 107°, lift intake .423/ outlet .443
asking for the complete kit 2000 € included the clutches & cam, flywheel etc. located in northern germany
best regards
