October 13, 2026, 12:58:31 pm
| |-+  For sale!
| | |-+  NEW Steering Wheel Quick Release hub
Author Topic: NEW Steering Wheel Quick Release hub  (Read 5006 times)
RMS Boxer Service
« on: July 06, 2014, 14:00:49 pm »
The Bolt-On quick release hub allows for quick removal of your steering wheel.
This is a bolt on quick release hub and requires a vehicle specific hub adaptor to mount.
The quick release is a 6-bolt pattern to fit 6x70 mm bolt pattern. Splines have a
very fine fit and no rattle when fitted as most cheap one have.
The part with the outer splines are made from steel and the flange can be turned
down so the part can be welded on the steering column.
I also have hubs to fit VW splined steering column.
I have two of  Quick Release hubs for sale.
Can deliver at SCC
Quick release hub €90 each
VW splined hub €40 each
/Rolf
broen messiaen
« Reply #1 on: July 30, 2015, 21:25:58 pm »
any change you still have it?
RMS Boxer Service
« Reply #2 on: July 30, 2015, 22:11:03 pm »
Maybe I've got another one Smiley
/Rolf
« Last Edit: July 30, 2015, 22:23:39 pm by RMS Boxer Service » Logged
broen messiaen
« Reply #3 on: July 31, 2015, 06:04:13 am »
check pm
