September 22, 2026, 01:30:27 am
| | |-+  TYPE III FULL FLOW......
Author Topic: TYPE III FULL FLOW......  (Read 13241 times)
« on: July 27, 2014, 04:51:15 am »
Ok, anybody have any pics of there set-up on the full flow before putting the shroud on?? Outlet is ok, it's the inlet. You Type III guys, you put the 90* up with a 45* or down?? Its tight!!!!!!
Ted
« Reply #1 on: July 27, 2014, 05:02:33 am »
Ted I did one a long long time ago. I don't remember much, but I think I used a slightly clearanced Berg 90 with another Berg 90 and I do remember having to manicure the shroud some and siliconing up the small window I had to make. This was 23 years ago so it's foggy now.
RhoadsVW
« Reply #2 on: July 27, 2014, 07:09:12 am »
I did one about six years ago and I can't remember all the twists and turns I had to do to get it to fit.  Just get some 90's and 45's and straight nipples and start fitting things together.  Have patients.  I know not much help, but have fun.
Der Renwagen Fuhrers
Andy
« Reply #3 on: July 27, 2014, 21:50:38 pm »
This is what I put together for the last Type 3 engine I built.
« Reply #4 on: July 28, 2014, 05:50:50 am »
i know it is much easier to enter the case from the bottom plunger on a type3. CSP makes a bolt on adapter that you can use in order not to tap and block of the main gallery.
Jesse Wens
« Reply #5 on: July 28, 2014, 08:42:52 am »
I used the csp adaptor as well. One thing to keep in mind is that you delete the original cooler this way. I mounted a remote cooler with fan next to the transaxle with a real wax element thermostat in between. Havent used the fan yet.
this way I could mount the fanhousing without any clearancing.
« Reply #6 on: July 30, 2014, 20:33:23 pm »
Thanks everyone, I pretty much did what you did Andy, worked out good, no mods to the fan shroud. Got lucky.. Grin
Ted
Griebel
« Reply #7 on: July 31, 2014, 18:34:55 pm »
Berg set-up
Instagram: c.griebel
       "BEYOND 4 INCHES"
          MIB,DENMARK
Catbox
Slave to internal combustion.
« Reply #8 on: August 04, 2014, 23:38:14 pm »
I know that I am late to the party....
But for somebody down the road that does the search thing there is also this option....
The side flow conversion from Brothers Machine.
They weld a set of bungs onto the side of the case, Mag or Alum and you no longer have to mickey mouse it to the oil cooler.
There is a plug that is threaded down the galley and sits between the holes.
No more oil pump mods or nasty fittings mazes to build.
Here is a screen shot of the machine costs...
I plan to have them do this mod for the 2332 that I have to build for my Square.  Grin
2manytoys
« Reply #9 on: August 05, 2014, 05:12:56 am »
That Brothers T3 looks like a slick setup for type 3 full flow. I will have to do something like that and I was thinking that the wishbone would have to be modified along with running the CB flat style pump cover.
Patrick Friel -..2manytoys, not enough time or money
PIMPPRIDE
« Reply #10 on: August 05, 2014, 21:00:33 pm »
does anyone have photos of the brothers side setup installed in a type 3?
I am just curious to see with all the engine tin in place how lines ect... routes...
with my engine coming apart soon for some updates, I am running into an issue with the full flow, currently I have the filter off the left rear bumper bracket... however my new CSP exhaust uses hangers off the left & right bumper bracket locations...
these two can't occupy the same space, so the filter needs to be moved
Anthony / ISP WEST
Catbox
« Reply #11 on: August 08, 2014, 17:04:05 pm »
I think I have seen pictures of it installed.
I will look around for them....
 Grin
« Reply #12 on: August 23, 2014, 23:24:31 pm »
Hmmm interesting, A friend is currently having a few issues with this........
Catbox
« Reply #13 on: September 09, 2014, 01:04:52 am »
Here is the one picture that I could find over on the samba....
« Reply #14 on: September 19, 2014, 00:44:38 am »
Hmmmmm I guess it would work  Undecided
« Reply #15 on: September 23, 2014, 15:47:28 pm »
It works great in my friends Baywindow double cab.
GeirJB
« Reply #16 on: September 24, 2014, 21:44:49 pm »
Thats not a solution on my engine now, its bolted together!
And wouldnt have been easy to weld those bungs on a old vw-case!?
« Reply #17 on: September 24, 2014, 22:40:24 pm »
Ah the friend in question Wink
Any news/updates??
