September 22, 2026, 22:18:05 pm
| | |-+  Another IDA lean stumble ranting ;D
Author Topic: Another IDA lean stumble ranting ;D  (Read 3911 times)
Erlend / bug66
Global Moderator
SCC Event
« on: July 29, 2014, 11:00:24 am »
Ok. I've already gone through the threads here, on ultimate, shoptalk, aussie-rotor forums and V8s forums.
They are all different Cheesy
My lean stumble is only at part throttle, stomp it and it's not there. But that could potentially be to noisy Cheesy
I'm on E85 btw.
Some spec
94x76
42/37 wedgeports
48 IDA w/ 40 vents
Jetting right now:
70 idle on 110 holders
225 main and 155 airs
F7 tubes
300 needles, stock rest.
28 degrees ignition (what it liked on 98 octane)
I have all the jets i might need, and F2s and F11s.
Same stumble on F11s, but haven't tried F2s.
More main and air to get the main in earlier?
More idle?
Any suggestions?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
« Reply #1 on: July 29, 2014, 11:54:53 am »
So you swapped fuel to E85 from 98 octane, then adjusted the jetting to suit?
but didn't adjust the timing?  Shocked
 what rpm does it happen at? roughly? is all your advance in by then? if it isn't then with E85 it might like more initial timing
I can't remember what cam it has in it, what is it?
If not timing then I would go up a size on idle jet 1st and see what that does
Erlend / bug66
Global Moderator
SCC Event
« Reply #2 on: July 29, 2014, 12:31:16 pm »
I've read that you can pick up more power with more timing, and that more timing on a NA engine is no bueno on E85..
Web 86C with 1,4 rockers.
pretty much exactly at 3000rpm. timing is set at 3000, so it should be all inn.
I've tried 75 idles at idle in the garage but was rich, like 10,5-11 at idle.
I'll try it after work on the road Smiley
The '67:
The '59:
Not yet..
« Reply #3 on: July 29, 2014, 23:15:00 pm »
Less idle fuel to stop the fuelling up down low, then fiddle with idle airs (do IDAs have them?) to extend it further through the transition to cover the part-throttle stumble maybe?
