September 09, 2026, 04:51:49 am
Latest Member: Bad Habit
| | |-+  60ft times and reaction times etc
Author Topic: 60ft times and reaction times etc  (Read 7164 times)
goose
« on: July 29, 2014, 19:48:08 pm »
only just had the first gentle runs in the car
never been racing before
the best time is below
1.0859 reaction
2.086 60ft
8.8862 @1/8
80.600 @ 1/8
13.6559 @1/4 et
100.660 @1/4 mph
what would be the effect of getting the 60ft down to 1.6
what would be the effect of getting the reaction time down to 0.7 ish
i am curious as to the potential in the car if the driver can improve
i look forward to your predictions
cheers Angus Grin
2015 the year finally racing
dannyboy
« Reply #1 on: July 29, 2014, 20:05:42 pm »
easy 12s then  Wink
8.77@156.8mph
O/FF 60
« Reply #2 on: July 29, 2014, 20:25:19 pm »
Reaction time has no affect on the ET at all so that will make no difference, it is only a measurement of your reaction to the green light,the clocks don't start until you actually move, typically a 1/10th in the 60ft is worth 2 over the 1/4 mile, 1.5x 60fts are quite realistic for a bug with good suspension set up and sticky tyres.
Its hard to calc the potential without knowing the weight and how hard you beat on it Grin  13.6@100mph using a guesstimate of 1825lbs says you are using about 150whp, but it cant calc wheelspin etc, mph is the best thing to go on but again the gearing has a huge affect
Does it have a close ratio box?
12s should be achievable with seat time and tuning alone  Smiley
goose
« Reply #3 on: July 29, 2014, 21:12:24 pm »
no it has a pro street box with a tall 4th unknown ratios and previous owner new nothing either.if it is from rancho will it have an ID stamped on it?
i can perhaps get me and the car weighed on sunday etc
with the engine fire before the first run it all turned into a baptism of fire
and now i have time to reflect i am looking at what is in the driver potential as my head was all over the place
the car is still set on the rich side and the limiter is only set at 6k
so i would like to set some targets to hit next time etc
Angus
MC Dyno Don
« Reply #4 on: July 29, 2014, 23:23:10 pm »
 First pass at Bug-in with my 63 Notchback in 1978 with radials was almost identical @ 13:67 and same mph... with some tuning  and traction I was able to manage down into the 12's//12:60's    Old School 78X90.5...42x37 non welded heads...125 w/1:25's...1 1/2 exhaust...42 Dcnf's///for comparison purpose only...  Hope this helps..?  Good Luck..!!
« Reply #5 on: July 29, 2014, 23:26:44 pm »
1.8 60ft on radials is something to aim for to begin with, hardly any street cars can do it without 4wd or an engine in the bum. Helps keep the V8s honest for the first 100m at least, they find it very annoying!  Grin
Reaction times, it sounds like you're waiting for the green to come up, then going "What? Oh! Hey, we're off!". That's not a criticism, just an observation.
Next time on the line, try timing the lights down the tree in your head, then launching on the last yellow, eg light, light, launch. My little boys are forever saying "1...2...GO!".  Cheesy
That should knock a second off your reaction time to make people pay attention.
« Reply #6 on: July 30, 2014, 09:38:34 am »
Seat time alone will probably gain you 1/2 a second, the more relaxed you are the easier it is to be consistent, 6k rpm sounds way to low, hasn't it got comp elims on it? what cam? with a tall ratio box it will be even worse, spinning it higher will keep it in the power better after each shift, are you using all 4 gears?
I am not sure how Rancho ID there boxes, maybe drop them a mail and ask?
