September 25, 2026, 14:01:29 pm
| |-+  For sale!
| | |-+  FOR SALE Pagan Princess Engine (2027cc WPS Turnkey Street Engine)
Author Topic: FOR SALE Pagan Princess Engine (2027cc WPS Turnkey Street Engine)  (Read 3356 times)
Jo Clifford
« on: August 17, 2014, 13:02:13 pm »
Built by Ian @ Wolfsburg Performance Services
This was built with no expense spared (like the rest of the car  Smiley) to be a reliable street cruiser and still able to put a smile on my face, which it has done even in the heat and traffic of Las Vegas  Smiley.  It has now covered less than 5000 miles.  It has always been meticulously maintained with oil changes every 1500 miles,
The spec is
2027cc
78.8mm Stroker Crank – Pauter
90.5 Pistons & Cylinders
Engle K8 camshaft
044 castings with WPS Mini D port job
40mm inlet port valves
35.5mm exhaust valves
Dual Valve springs
Match ported manifolds
1.4:1 Autocraft rockers
Aluminium Case (stroke clearanced, full flowed and bored for 90.5mm cylinders)
Berg Oil Pump – full flow with cover
Berg Deep sump
009 Distributor, with electronic ignition
Blue coil
45 DRLA carb kit – hex bar linkage
Type 3 Welded and Balanced Fan
Heavy Duty Clutch
1 5/8” Stainless steel  custom built exhaust – to exit stock location
Compression ratio just under 9 to 1
Gloss black powder coated tin
£4995 – Located in Essex
Reason for sale Pagan Princess was sold less engine as buyer wanted to fit a stock engine instead.
Also have matching short axle, swingaxle gearbox built by Cogbox for sale, if interested ask for specs.
https://linktr.ee/Redheadautoupholstery?utm_source=linktree_profile_share
http://www.rjvolksperformance.com/
Living the dream, not just talking about it ;o)
"Don't talk, just bring it" - Hector Urias
Jo Clifford
« Reply #1 on: August 17, 2014, 18:10:28 pm »
Gearbox info:-
Built by Cogbox, done less than 5000 miles, 4.12 R&P, heavy duty side plates, close ratio 3rd & 4th (1.48 & 1.05)
£1500
Jo Clifford
« Reply #2 on: August 22, 2014, 06:59:03 am »
Gearbox info:-
£1500
Sale Pending on the gearbox  Smiley
