September 23, 2026, 03:24:30 am
| | |-+  MSD + master battery switch ?
Author Topic: MSD + master battery switch ?  (Read 4680 times)
Sepi
« on: August 29, 2014, 11:38:02 am »
My new 2332 is so happy running engine and doesn't want to stop from ignition switch at all. Cutting off with a two pin main switch is not good for alternator, so I have now the FIA approved with 4 other pins. Before I'll do anything serious, please advise me and tell how to make wiring and connections right with MSD 6 AL.
I have done the MSD wiring like the picture above and I supposed to do the main switch wiring like it is shown under - sorry for the poor quality of the pic.
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: August 29, 2014, 17:21:38 pm »
It will not stop (if you wired after msd's direction because it's connected directly to the battery with +/-
You could run one of those wires through a cut of switch.
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Lanny Hussey
« Reply #2 on: August 29, 2014, 17:38:57 pm »
You need to install a diode on the alternator field(idiot light) wire. MSD has instructions for this.
Sepi
« Reply #3 on: August 29, 2014, 18:54:38 pm »
I was told with a PM that ignition light gives a route for MSD to get a current and I'll test that.
BTW, which way do I connect the diode if I connect it on the signal cable of alternator - going to alternator or coming from?
MattiK
« Reply #4 on: August 30, 2014, 07:01:42 am »
You cannot put the diode on signal cable. The current must flow in both directions.
Sepi
« Reply #5 on: August 30, 2014, 07:09:49 am »
... I was thinking about too easy way... Embarrassed
