September 23, 2026, 08:08:18 am
| |-+  For sale!
| | |-+  Engine parts
Author Topic: Engine parts  (Read 3073 times)
SuperTrigger
« on: September 01, 2014, 08:49:10 am »
1)SuperFlow heads, 1200€ 1100€
For 94mm bore
44x37,5 RST Valves
K800 spring
Titan retainers
compustion chamber 48cc
Berg valvecover converter set, you can use stock valvecovers
intakemanifolds DRLA spacing
I have Flow numbers also
Dynoed from 2332cc engine CR 11.0 + FK46 cam + 1,5:1 rockers + MS1 V2.2 fuelinjection, 234hv / 288NM from flywheel.
3) Used FK46 cam + lifters (Scat) 120€ 100€
4) Throttlebody pair DHLA spacing 48mm 120€
- No throttle plates and axels
5) Throttlebody pair IDA spacing 50mm 380€ 350€
- about 40 mm high
- self made, needs some kind of throttle stop and Idle control
6) Airfilters 50€
 Like these -->http://hotcars.net/p.../big/5943-1.jpg
9)Transmission 1300€ 1000€
- Stock case
- Aluminium sidecover
- 1-2 gears stock,
- 3 gear 1,51
- 4 gear 1,25
- Finalgear 4,125
- Diiff
10) Petronix Billet jakaja 220€ 200€
used only for one dyno session and 4 starts at strip.
http://aircooled.fi/...illet-pertronix
Parts are in Finland and sending cost's will be added.
Will take pictures if requested.
Contact with PM or mail markopuikkonen (@) yahoo.com
« Last Edit: September 30, 2014, 10:08:35 am by SuperTrigger » Logged
SuperTrigger
« Reply #1 on: September 30, 2014, 10:09:03 am »
No need for parts?
Possible to Trade for 4" case.
« Last Edit: September 30, 2014, 10:11:48 am by SuperTrigger » Logged
