October 13, 2026, 22:34:29 pm
Which cam is best
Topic: Which cam is best (Read 8609 times)
taffy apple
Which cam is best
September 10, 2014, 15:30:16 pm »
Could anyone advise me out of the two cams I have, which would work better with a type1 2180 running nitros.
They are both webcam, the one that came out of the engine is a 109, the one I got on the shelf is a 251.
Many thanks Graham.
Re: Which cam is best
September 10, 2014, 17:01:47 pm »
Hi Graham
109 is small and 251 is big!!!! Neither would be my choice for that application unless you got real big heads then the 251 would work
What heads and rockers have you got?
taffy apple
September 10, 2014, 17:22:19 pm »
Hi Richie, the heads are street eliminators that have had a bit of work, the rockers we took off are 1.4.
September 10, 2014, 18:15:20 pm »
The 251 is probably going to have to much lift for the valve springs in those heads
taffy apple
September 10, 2014, 20:26:44 pm »
Could you recommend a cam that best suit Ritchie, and do you stock it?
Last Edit: September 10, 2014, 20:45:39 pm by taffy apple
K-Roc
September 10, 2014, 21:24:27 pm »
I have tried several cams in my 2332 with a 50 shot and I am going back to my 86C, reasonably easy on the valve train and it made the most power on the Nitrous with it.
My feeling is that for a small shot of nitrous use the cam that makes the most power ( for the combination ) normally aspirated. and it will work well on the button.
for big shots of Nitrous its a different story.....
September 11, 2014, 08:52:12 am »
Quote from: K-Roc on September 10, 2014, 21:24:27 pm
Agreed
I would put a FK8 in your engine Graham if I was building it, cant go wrong with it, you would have to check for coil bind etc, I don't know how much lift you have with the 109? as looking at Web cams site it looks to me like its not for 1.4 rockers
taffy apple
September 11, 2014, 10:02:30 am »
Thanks for the advise k-Roc and Richie, I will go with that cam, I need to find out if the rockers are actually 1.4, as they are not recommended with the 109. Ive had a look on them but can't see anything but a vw logo stamp on the arm.
I got the engine complete, so only working on what I was told. Is there a easy way to find out, what rockers I have?.
Many thanks Graham
September 11, 2014, 10:57:08 am »
Quote from: taffy apple on September 11, 2014, 10:02:30 am
Many thanks Graham
They have to be 1.1 or at most 1.25 with a vw logo, maybe if you put a pic up someone will identify them, other way is to measure them on an engine to see what they give
I have FK8s here if you need one
taffy apple
September 11, 2014, 11:20:23 am »
Pretty sure there 1.1, the cup is drilled in the centre and they are all stamped up vw logo, not gonna be any good for the fk8,.
Could you put it to one side Richie, as it looks like I got a new parts list starting ;-).
taffy apple
September 11, 2014, 12:01:47 pm »
http://s1383.photobucket.com/user/grahamwhite74/library/
http://s1383.photobucket.com/user/grahamwhite74/media/imagejpg1_zps613d8bd8.jpg.html
Last Edit: September 11, 2014, 12:07:28 pm by taffy apple
