October 13, 2026, 22:34:35 pm
JPM MS230 porting?
Topic: JPM MS230 porting? (Read 8884 times)
neil68
JPM MS230 porting?
September 10, 2014, 19:30:06 pm »
Has anyone ported their MS230 heads?
I'm running these heads as "received", except for fly-cut to ~50 cc. Would like to get a few more ponies out of them, for drag racing with my 2332 cc Beetle combo.
Thanks!
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
Re: JPM MS230 porting?
September 10, 2014, 20:06:38 pm »
Hi Neil
Johannes did some work to mine as they were for turbo use, I am sure I have seen some getting work at Heads up a couple of years ago, even though they are good out the box there is room for improvement as shown by JPM offering the 2 newer versions
K-Roc
September 10, 2014, 21:17:24 pm »
Hi Niel a 230 CFM port will support over 250 HP.
( Make your car lighter
That thing would be a rocket at 1750 Lbs Car and driver.
didi
September 10, 2014, 22:21:10 pm »
Hi
Johannes ported my heads to 275cfm / 28cm H2O / 14mm Lift
Didi
Didi - Aircooled VW
http://didivw.blogspot.com/
neil68
September 11, 2014, 23:52:27 pm »
Quote from: K-Roc on September 10, 2014, 21:17:24 pm
Not sure that I have the full 230 cfm with my cam lift, but I get what you're saying! I'll have to check the "weight saving thread" more closely, as my last trip to the scales showed 930 kg (2,045 lb).
Neil
Dynojet Test:
neil68
September 11, 2014, 23:54:50 pm »
Quote from: didi on September 10, 2014, 22:21:10 pm
Hi
Didi
Thanks for posting the photo!
Neil
Dynojet Test:
RMS Boxer Service
September 12, 2014, 14:55:17 pm »
Peter Bang, Jaegermeister bug, had his 4" MS230 heads ported at Heads Up Performance years ago.
Roger did some work to them but said they where pretty fine compared to other out of the box heads.
As far as I .remember Roger did most work in the exhaust port and camber.
The engine (oxyboxer) is now in the Ultra Rat.
/Rolf
September 12, 2014, 16:20:54 pm »
Neil,
What kind of lift are you running?
I flowed my MS230s and made past 230 at 600" with no work. They make the number and a bit more!
TxT
JIMP
September 12, 2014, 17:15:32 pm »
I double that
my t1 2387cc made 253HP with no porting, the only "porting" was to blend the seats with the runners and match port the intakes, the black anodizing was still in the runners, not removed, it did those with an fk89/87 if I recall correctly, not even raptor, no need in my opinion to work on them unless you need only to drag race, not street drive with the car
Friendly
Dimitrios
neil68
September 12, 2014, 18:29:59 pm »
Thank you, Tom & Dimitrios. Good to know that the MS230 flows well "out of the box". My preference is to leave the heads untouched and look elsewhere for improvement. It would also make it easier to sell them, if I decide to get serious about racing and move up to the MS250.
Current lift with my Raptor cam is 15.2 mm (0.599") and I'm using CB manifolds (CE style).
Neil
Dynojet Test:
Erlend / bug66
Global Moderator
SCC Event
September 12, 2014, 18:34:33 pm »
I think that the Bugpack SF-intakes have a smoother curve in it. And a bit shorter than CB's.
Worth a test
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
