October 13, 2026, 05:01:16 am
| | |-+  Valve Length
Author Topic: Valve Length  (Read 4148 times)
kraftkaefer
« on: September 17, 2014, 12:31:44 pm »
Hi,
i have a question about valve lengths, because i have to cut some titanium ones to the right lenght to fit in some Angle Flow heads.
What are the lenghts of the valves in Autocraft, Pauter.... heads ? Is it the same like in Competition Elis oder Super Flow? 118mm or longer ?
Thanks for helping
Stefan
www.kraftkaefer.de
FULLA GROFFD Drag Racing
dangerous
« Reply #1 on: September 17, 2014, 22:46:37 pm »
Traditionally Autocraft and Pauter heads came with 11/32" stem valves unless custom ordered with some thing else.
The first production runs of Autocraft had valve of length 5.04",(128,016mm)
and this is also the length I used in my first Pauter heads.
I think it is .100" longer than std small block Chevy (4.94"= 125.476mm),
but with a longer .390" tip length above the collet, to allow the retainer to clear the rocker arms.
Probably a Windsor ford valve come to think of it!
We eventually added .100" to these lengths to make room for better springs and the larger lifts.
My current CD heads use a length of 5.340"
The valve length you use, will need to be close to the original
unless you like to muck around with rocker stud locations to get the correct geometry.
kraftkaefer
« Reply #2 on: September 20, 2014, 07:14:21 am »
Thanks for helping me, dangerous !  Smiley
If there´s something going on with my 3.0 Pauter project, i will share some pics.  Grin
« Last Edit: September 20, 2014, 07:18:29 am by kraftkaefer » Logged
www.kraftkaefer.de
