October 13, 2026, 07:24:18 am
8.02 @ 169 mph
Topic: 8.02 @ 169 mph (Read 28374 times)
Jo Clifford
Re: 8.02 @ 169 mph
Reply #30 on:
September 23, 2014, 07:18:48 am »
and finally the Wheelie bar cam video from the 8.08
http://youtu.be/dFUhdKzA5qc
https://linktr.ee/Redheadautoupholstery?utm_source=linktree_profile_share
http://www.rjvolksperformance.com/
Living the dream, not just talking about it ;o)
"Don't talk, just bring it" - Hector Urias
dannyboy
Re: 8.02 @ 169 mph
Reply #31 on:
September 23, 2014, 08:55:40 am »
ROOF CHOP
8.77@156.8mph
O/FF 60
Re: 8.02 @ 169 mph
Reply #32 on:
September 23, 2014, 10:21:16 am »
Quote from: dannyboy on September 23, 2014, 08:55:40 am
ROOF CHOP
I would actually like to drop the screen down to early size but the cage is already to high so no real gains to be had there without starting again
WPS
Re: 8.02 @ 169 mph
Reply #33 on:
September 23, 2014, 10:59:22 am »
Take the screen out and get some goggles!! You know it makes sense..... It'll mess ya hair up abit tho' so maybe not?
Well done by the way!! Looks and sounds the nutz!!
Wolfsburg Performance Services
WolfsburgPerformance.co.uk
Instagram: wpsengines
07880-311850.
mr horsepower
Re: 8.02 @ 169 mph
Reply #34 on:
September 23, 2014, 17:21:06 pm »
You can take the bugshield from my truck
dannyboy
Re: 8.02 @ 169 mph
Reply #35 on:
September 23, 2014, 18:43:05 pm »
Quote from: richie on September 23, 2014, 10:21:16 am
ROOF CHOP
roof and cage chop
8.77@156.8mph
O/FF 60
Airspeed
Re: 8.02 @ 169 mph
Reply #36 on:
September 23, 2014, 18:48:17 pm »
Quote from: richie on September 21, 2014, 20:55:30 pm
I have a few ideas for the winter to hopefully improve it for next year, definitely need to look at helping it cut through the air better, and there is more in the 60ft to come, then on both passes as I shifted into 2nd I had huge wheelspin, [over 33mph higher wheelspeed than actual car speed] so some work there as well. It will keep me busy anyway
Videos are uploading now so should be up in the morning
Richie, I was looking at the slow-mo and reading your above comment about wheel slip. My first thought was that you see the rear tires rebound and I imagine the high wheel slip comes from such a moment. It looks like the car is hardly suppressing in suspension, mostly its the tire that seems to act as your suspension (eggaguratedly speaking).
Maybe a bit extra suspension travel might keep the tires longer in contact with the track?
BTW, awesome time! The 1/8 mi tells you're on 7's path imo, indeed the aero must be whats different with Chris' time x mph.
Rocket Ron
It's old school for a reason
Re: 8.02 @ 169 mph
Reply #37 on:
September 26, 2014, 20:02:36 pm »
Just another 0.15 and you'll be there
Good luck for next season
13.12 @ 101.84
Grooving out on life
Re: 8.02 @ 169 mph
Reply #38 on:
September 26, 2014, 20:13:12 pm »
well done! i hope to see it sometime life next season. take care.
Re: 8.02 @ 169 mph
Reply #39 on:
September 26, 2014, 20:59:05 pm »
Quote from: Airspeed on September 23, 2014, 18:48:17 pm
Hi Walter
the 8.08 slo mo wasn't the best as it was 1st pass on a new clutch and set up was a total guess, it hit too hard and smacked the wheelie bar which unloaded everything, I know I am doing it different to most with the single wheel and stiffer wheelie bar set up, on the next pass 1st gear was real good, just 2nd that needs smoothing out now.
I got so many ideas on how to improve it and be more consistent but lack of track time this year slowed that up, when you only get 2 or 3 passes over a weekend its hard to confirm if something does or doesn't work, that's not enough data for me and then the next meeting usually the conditions are different and so are the results!!!! But if it was easy everybody would be doing it
Re: 8.02 @ 169 mph
Reply #40 on:
September 26, 2014, 21:02:08 pm »
Thanks to everyone for all the positive comments, next year should really be something and we have a couple of things in the works that should make it even better
, roll on Easter
schneeky
Re: 8.02 @ 169 mph
Reply #41 on:
September 27, 2014, 17:08:25 pm »
What can i say Rich, massive massive congrats to you and the team. Gutted that i couldn't be there (i was busy getting married
Looking forward to catching up with you and Jo at the track next season mate.
All the best...Steve
