September 22, 2026, 21:52:57 pm
| |-+  For sale!
| | |-+  Race car for sale - European ProStock Record holder - 200' - offer
Author Topic: Race car for sale - European ProStock Record holder - 200' - offer  (Read 6141 times)
johandryselius
« on: September 29, 2014, 18:06:58 pm »
European Pro Stock Record holder for sale! Five 1/4 mile passes and five 1/8 mile passes on engine, gearbox and tires. Best 9,85@218,8 and 6,25@176,2. Serious inquires only. Only the best of the best! Complete car 200 000SEK/21 500 €. Split parts: Car/Engine/Gearbox - make offer. Everything can be discussed dependent on what parts that comes along. Selling due to new project to catch the last record. PM me - no discussion in thread.
Johan
« Last Edit: December 03, 2014, 06:31:25 am by johandryselius » Logged
1600cc Challenge Porsche 356:
9,4386@242,48km/h; 6,1229@193,15 km/h 1,50 60 foot @ Kjula Dragway 2022
1600cc Challenge Buggy:
9,5112@225,42 km/h; 6,0624@185,85 km/h 1,38 60 foot @ Kjula Dragway 2020
Europes quickest ProStock VW:
9,8538@218,80 km/h; 6,2569@176,24 km/h 1,35 60 foot @ BRC Tierp Arena 2014
« Reply #1 on: September 30, 2014, 14:55:37 pm »
So we can not race next year ??   Hopefully with the new owner  Smiley - good deal
johandryselius
« Reply #2 on: October 01, 2014, 12:49:34 pm »
Udo!
If I get it sold you can race the new owner and me when I'm done with the new - otherwise with me!
Smiley
Johan
johandryselius
« Reply #3 on: October 02, 2014, 14:37:48 pm »
If you need any specs - let me know. Will consider all offerings!
Smiley
Johan
johandryselius
« Reply #4 on: October 03, 2014, 14:45:01 pm »
CAR:
RLR chassis - see build pics etc at www.j-teamracing.com, 520 kg at start without driver
ENGINE - 2388 cc Type 1 - 302,5 HP at 8400, torque 294 Nm at 6600:
Case: AutoLinea
Crankshaft: SCAT flanged billet 86 mm T4 all mains
Flywheel and clutch: SCAT with RLR Rev 6 clutch set-up - single disc
Rods: SCAT 5,7” H-beam
Rod bolts: Carrillo SPS, 12 point head
Cylinders: JPM
Pistons: 94 mm JE ultra low JPM
Camshaft & Gears: JPM Raptor custom grind 17,35 mm lift, flat tappet, Magnum gears
Lifters: JAYCEE tool steel
Cylinder head studs: Raceware Hi tensile 8 mm
Heads: JPM MS 250, CR 15,4:1
Rockers: JPM 5 point
Valves & Springs: Manley Titanium 48x38 mm, Oteva springs
Retainers: Titanium
Pushrods & Tubes: Manton double tapered, JPM tubes
Carbs: Gene Berg 58’s on welded angle flow manifolds, 50 mm venturi, Teflon coated by Tommy Tc Costello , JayCee linkage
Oiling: CB 4 Gear dry sump, special case modifications, JayCee bypass
Distributor: JAYCEE crank Trigger
Pick-up: JAYCEE crank trigger with with alternator combo
Exhaust: CSP Wasp 3
GEARBOX:
Case: Rhino with HD sidecovers
Gear set: Dogring from Kuplapaja - 3,40; 2,31; 1,69; 1,28
Hockeystick & Modifications: HEAT
R&P: Klinkenberg/HEAT 3:88
Spool: JAYCEE
Axles: RLR 5” short
EXTRA:
Ignition box: MSD 7 AL 3
johandryselius
« Reply #5 on: October 09, 2014, 10:27:03 am »
Any offers!?
Smiley
Johan
johandryselius
« Reply #6 on: November 12, 2014, 20:33:16 pm »
Will consider all offers - any questions - just ask!
Smiley
Johan
johandryselius
« Reply #7 on: December 02, 2014, 22:38:38 pm »
bump - new price
