October 13, 2026, 02:50:37 am
| | |-+  Fuel tank breather/roll over valve
Author Topic: Fuel tank breather/roll over valve  (Read 11679 times)
« on: October 02, 2014, 20:34:25 pm »
My oval got pulled up at scrutineering for having a fuel cap that would leaked If the worst happened and the car rolled over.
I have sealed the cap as suggested but will obviously the tank will need a new breather. What do you guys run, I've seen braided linefrom the filler neck? Also heard something about a one way valve?
Any advice would be awesome, running out of time for drag day!!
Lee
« Last Edit: October 07, 2014, 18:00:03 pm by leec » Logged
Andy Sykes
« Reply #1 on: October 02, 2014, 21:01:46 pm »
the one way valves work but you may still need to fit a coiled tube, as they have know way of knowing if the valve works so you may as well just fit a tube
cheers andy
Sepi
« Reply #2 on: October 02, 2014, 21:07:29 pm »
I did this kind of system to my -59. It has the one way valve and opened filter.
« Reply #3 on: October 02, 2014, 21:09:12 pm »
Jo's car has a 2 piece bolt on roll over valve,
http://www.jegs.com/i/JAZ-Products/547/834-006-11/10002/-1?parentProductId=751554
 just drill a hole in the filler neck, flatten that area slightly so it will seal and bolt it on, then some -6 hose to exit out underneath, on the old car I welded a -8 fitting on the tank filler neck and used the 1 piece roll over valve that then bolts on to that.
http://www.jegs.com/i/JAZ-Products/547/834-208-06/10002/-1?parentProductId=751554
That's what I use on most other stuff now, I think I got a couple of them[ -8] in stock if you are stuck but you need either need a tank fitting like this
http://www.jegs.com/i/JAZ-Products/547/832-108-11/10002/-1?parentProductId=747212
or to have the tank out to get a fitting welded on
« Reply #4 on: October 02, 2014, 21:21:00 pm »
Great, thank you guys.
Richie, the 2 piece jegs valve, do you have them in stock?
Will they act as a breather too?
I assume ou just run hose from the fitting with a loop in it to vent under the car?
Lee
Ps, pics would help my tiny mind!
« Last Edit: October 02, 2014, 21:31:20 pm by leec » Logged
spanners
« Reply #5 on: October 02, 2014, 22:12:44 pm »
Lee
MSA regs require a "roll over valve"  in breather lines, I run double breathers with two valves venting into a breather tank, they are mounted vertically for correct function, I fear fire, more so when upside down and seeing stars, so no open tank breathers, running them into a catch/breather tank is a scruteneers delight also.
Best regards, spanners.
« Reply #6 on: October 03, 2014, 08:47:33 am »
Lee
Haven't got the 2 pieces one sorry, that was a one off as tank was powder coated, yes its a vent until fuel pushes against it and then closes it off, you can do as Spanners says and run hose into a catch can or just vent outside the by the beam
« Reply #7 on: October 03, 2014, 08:49:11 am »
Oh and I am 600 miles away from car so nothing I can do about a pic at moment
« Reply #8 on: October 03, 2014, 10:12:03 am »
Thanks Richie,
If you have one of the -8 ones in stock, the one requiring the fitting welding on the tank I will take one of those
Lee
dannyboy
« Reply #9 on: October 03, 2014, 22:12:31 pm »
tourques do a bolt in one i fitted one to my jaz tank  search on ebay
8.77@156.8mph
O/FF 60
« Reply #10 on: October 07, 2014, 17:54:05 pm »
Right, sorted Grin
Thank you to Richie+Jo for supplying the valve super quick and big thank you to Alex Taylor for neatly welding the fitting to the Tank. A job which I couldn't watch initially!!
Lee
Rocket Ron
It's old school for a reason
« Reply #11 on: October 07, 2014, 20:51:53 pm »
Looks great lee
Last time Alex welded a fitting to my tank It went off with a real bang and ballooned the tank, I'm sure I can get and extra 1/2 gallon in there now lol
13.12 @ 101.84
Grooving out on life
« Reply #12 on: October 07, 2014, 21:48:20 pm »
Looks great lee
We talked about your tank. When he fired the first tack I was cowering in the corner of the workshop Shocked
