October 13, 2026, 05:01:05 am
Best ball joints to use with lowered spindles
Topic: Best ball joints to use with lowered spindles (Read 5776 times)
Matt Tobias
October 06, 2014, 22:59:05 pm »
Hey guys finally getting back to work on my 67 and I recently picked up some dropped spindles. I want to put adjusters in the beam as well to fine tune ride height. If I end up lowering the car a bit more than the spindles provide, will stock style ball joints be okay?
TIA,
Matt
Mike Maize
Re: Best ball joints to use with lowered spindles
October 07, 2014, 02:48:59 am »
Yes they will.
Matt Tobias
October 07, 2014, 03:29:27 am »
Thank you Mike!
hotrodsurplus
October 22, 2014, 13:13:56 pm »
a bit off topic but when you build your beam make sure to install the adjusters to both lower the car and raise it so you can lift the nose to stock height for towing, etc. Most adjusters (at least the Sway-a-Way type) offer enough range to get the car quite low even if installed to lift it a little bit.
October 23, 2014, 10:49:38 am »
But don't do what i did, I put both adjusters with a deliberate slight rotation. This meant that when fully wound down the nose touched the ground! I could not get a jack under the front of the car. It looked cool, but was so impractical. Swapped the beam for a stock one and now only run dropped spindles.
kev d
October 23, 2014, 22:22:15 pm »
I did that too
Off with it again & repeat the cut, weld refit...
Was low though!
56BLITZ
October 25, 2014, 22:16:22 pm »
Quote from: hotrodsurplus on October 22, 2014, 13:13:56 pm
. . . make sure to install the adjusters to both lower the car and raise it so you can lift the nose to stock height . . .
Hey Chris, does this also apply when using stock spindles?
Jesucristo es mi Seņor y Salvador!
October 26, 2014, 00:51:12 am »
I'm thinking that you wouldn't want to raise the car much above stock.
Matt Tobias
October 26, 2014, 20:59:15 pm »
all good info, thanks guys!!!
