September 22, 2026, 11:51:36 am
| | |-+  Jamar rear disc help needed
Author Topic: Jamar rear disc help needed  (Read 17251 times)
« on: October 14, 2014, 16:23:57 pm »
Hi guys,
Just fitted my Jamar rear discs to the Notchback project.
I can't for the life of me work out the caliper brackets or how the calipers fit. I have a suspicion the calipers are not the correct ones for the kit I have, but I am tired and have ear ache so maybe I am jus being silly?
Caliper body seems to thick to fit!! Will try and take a couple of pics later
Anyone got a link to fitting instructions?
Lee
« Last Edit: October 14, 2014, 16:50:10 pm by leec » Logged
Jonny Grigg
« Reply #1 on: October 17, 2014, 00:00:29 am »
Which kit do you have? If it is like mine- which started out as the 4x130 PCD then I'll take some pictures when I get home tomorrow
No Compromise. O/FF111
Stripped66
« Reply #2 on: October 17, 2014, 06:25:52 am »
Are these the calipers and brackets I sold you? If so, the bracket replaces the stock backing plate; it gets sandwiched between the bearing carrier and retainer. The caliper then mounts to the inside of the bracket. You can adjust the offset of the caliper by changing the number of washers between the bracket and caliper.
The rest of the "clearance" will depend on the offset of the rotor/hats you acquired (assuming "too thick to fit" implies the caliper is hitting the wheel-mounting surface?).
« Reply #3 on: October 17, 2014, 07:07:43 am »
Hi guys,
Thank you for the replies.
Yes, they are the calipers and brackets I got from you Smiley
The caliper is hitting the rear of the wheel mounting face, almost like the caliper is too wide.
I have the brackets mounted as you describe, although I wasn't sure which way round they go. In the end I put them with the 'Jamar' logo faxing towards the gearbox, not towards the brake disc.
Will try and get some pics this weekend to show what I mean/doin wrong!!
Lee
dannyboy
« Reply #4 on: October 17, 2014, 10:56:53 am »
it might be the calipers are twin pots and wont fit between disc and hub? if so you need the single piston wilwood calipers i think strange do them as well this is the same with neal wide 5 disc kits they use single pot calipers to reduce the offset i think? if the kit is made up out of different kits it might be the issue a smaller pcd kit can use a better caliper as it doesent get foulded  by the large 5 hub
8.77@156.8mph
O/FF 60
Stripped66
« Reply #5 on: October 17, 2014, 13:32:01 pm »
That is correct; the recess machined into the bracket (where the logo is) faces the bearing carrier/transaxle.
Are you using a Jamar rear hub?
« Reply #6 on: October 17, 2014, 17:39:08 pm »
Thanks Danny, that's exactly what I think has happened
Yes, using Jamar hubs.
Think its the price I pay for buying bits here and there!!
Lee
Stripped66
« Reply #7 on: October 17, 2014, 18:17:36 pm »
With the caliper free of the bracket, does it fit within the wheel-mounting surface when centered over the disc (this would be a caliper-width/hub mismatch if it did not fit)? If the caliper will physically fit over the disc and within the wheel mounting surface, how far off are the calipers from fitting the bracket? Could this be a hub-spacer issue and not a bracket issue?
dannyboy
« Reply #8 on: October 17, 2014, 18:53:43 pm »
the calipers are not cheap to buy i had to import them from the states to complete my neal front setup and never even ended up fitting it  Roll Eyes Smiley
8.77@156.8mph
O/FF 60
« Reply #9 on: October 17, 2014, 19:09:36 pm »
Caliper doesn't fit even without caliper bracket
Lee
dannyboy
« Reply #10 on: October 17, 2014, 19:18:04 pm »
these are the ones you need i think http://www.wilwood.com/Calipers/CaliperList.aspx?subname=Dynalite%20Single%20Floater
8.77@156.8mph
O/FF 60
Stripped66
« Reply #11 on: October 17, 2014, 19:31:35 pm »
Lee
What Jamar hubs are you using? The calipers you have are their current 2-piston design (DBBCAL)...I'd be surprised if their 4 or 6-piston calipers are more narrow than those 2-piston calipers, and further surprised that their hubs wouldn't work with all of the calipers they manufacture.
Pictures and measurements!
dannyboy
« Reply #12 on: October 22, 2014, 19:34:40 pm »
was comparing a set of wilwood wide 5 discs with a neal set and the wilwood ones have about 50 mm between disc and insode of hub,and neal ones are about 25mm
if i remember correctly the neal and jamar are very simular
8.77@156.8mph
O/FF 60
« Reply #13 on: October 22, 2014, 19:42:53 pm »
Have you got a set of wilwoo wide 5's then?
Lee
Stripped66
« Reply #14 on: October 22, 2014, 21:41:47 pm »
The calipers and brackets Lee has came from this Jamar brake kit:
The distance between the disc and wheel mounting surface is about 50mm in that kit, and those hubs will fit any of Jamar's 2, 4, or 6 piston calipers.
Lee, any pics or measurements of your Jamar hubs?
« Reply #15 on: September 06, 2015, 19:26:25 pm »
Hi guys,
Thought I would have another look at the calipers again with a clear mind. Here is a picture showing the issue I have. It shows the caliper fitted to the rotor/disc with the pads either side, but shows how the body of the caliper is just too wide to fit between the hub and the rotor
« Last Edit: September 06, 2015, 19:30:16 pm by leec » Logged
« Reply #16 on: September 06, 2015, 19:32:24 pm »
Chip
« Reply #17 on: September 06, 2015, 20:30:18 pm »
Those rotors look super skinny! How wide are they? A little less than 10mm is pretty much the standard street or race weight rotor thickness in the VW aftermarket. Those look very skinny, almost like they are the dune buggy super light design or something.
dannyboy
« Reply #18 on: September 06, 2015, 22:24:42 pm »
as i said they are for the single pot spot calipers  Wink
8.77@156.8mph
O/FF 60
dannyboy
« Reply #19 on: September 06, 2015, 22:28:04 pm »
if you are using spindle mount fronts with no brakes  it might be worth keeping  the calipers and change hubs/rotors .if not then just change calipers
8.77@156.8mph
O/FF 60
« Reply #20 on: September 06, 2015, 22:40:56 pm »
Thanks Danny,
Got discs on front so will just change the rear calipers
Lee
Stripped66
« Reply #21 on: September 09, 2015, 23:54:43 pm »
Those are some funky hubs. Here are the hubs your calipers/brackets came with:
Like Dannyboy said, a single-piston caliper is probably all that will work with those hubs.
Elnef
« Reply #22 on: September 26, 2015, 10:36:05 am »
I have just looked at mine I have 47mm between rotor and disk
I took a photo but too big for here give me a mail and I will send them
« Reply #23 on: September 26, 2015, 11:50:50 am »
Thank you
PM sent
Lee Grin
