October 14, 2026, 01:05:47 am
cam vs. coilbind
Topic: cam vs. coilbind (Read 6164 times)
bang
cam vs. coilbind
October 18, 2014, 19:17:50 pm »
hey.
how many mm gab should i keep before coil bind? have coil bind at 22 mm lift. my heads flow up to 20mm is 2 mm clearance okay before coil bind?
Stripped66
Re: cam vs. coilbind
October 18, 2014, 19:55:09 pm »
Follow the manufacturer's recommendation. The clearance at coil-bind contributes to damping spring harmonics, so you don't necessarily want to increase this clearance significantly, especially if you're suggesting running 20mm of valve lift...that's going to require some serious valvetrain, so setup is not trivial (shimming the spring, using offset keepers, or cutting the spring pocket should all be considered to achieve proper clearance). 2mm is in the ballpark of what many manufactures recommend, but not knowing what springs you're running I couldn't say otherwise.
bang
October 18, 2014, 21:44:20 pm »
running k800 and pauter 1,5 roller rockers.
Stripped66
October 18, 2014, 22:26:34 pm »
K800 is the wrong spring for 20mm of lift.
jaqo
Bugster Team
October 22, 2014, 21:55:27 pm »
k-800 coil bind at 1.085
http://www.kmotion.biz/springdat.htm
http://www.kmotion.biz/instht.htm
October 23, 2014, 19:53:32 pm »
Quote from: Stripped66 on October 18, 2014, 22:26:34 pm
I think the same. 20mm you need other springs. i have some nice PSI now but have no results
www.Udobeckertuning.de
Jonny Grigg
November 05, 2014, 22:21:08 pm »
What spring would you use with that kind of lift. When mocking up my motor this summer we ended up with 17mm lift, which was right on the knuckle of coil bind.... But my rockers measured out at 1.55 instead of 1.4 so have now gone to Pauter. I haven't mocked back up yet to see what I have got......
No Compromise. O/FF111
