October 13, 2026, 00:05:03 am
| | |-+  What valve spring ?
Author Topic: What valve spring ?  (Read 15549 times)
Elnef
« on: October 25, 2014, 07:44:34 am »
I need a new set of valve spring for my engine but what brand will be up to the job ?
200/500 pressure Chevy size 1,550" 8500/9000rpm 17mm lift
I have pauter heads ti valve and retainers
John
MeXX
« Reply #1 on: October 25, 2014, 09:23:58 am »
Dear John
Iīm using PSI brand and have about 40 sets in your range in stock...
If U give me all information I can let U know which will fit.
The other brands I would recommend is PAC and Manley NexTeC...
So let me know...
MeXX
« Last Edit: November 30, 2014, 22:38:11 pm by MeXX » Logged
Drag or Die
Elnef
« Reply #2 on: October 26, 2014, 16:17:54 pm »
Thanks Mexx
what is lifetime on at set of psi spring in a engine like yours ?
MeXX
« Reply #3 on: October 26, 2014, 20:26:31 pm »
Thanks Mexx
Hi John
This is now the second set Iīm runninī and after this season (15 races ) there is no measurable difference.
MeXX
Drag or Die
« Reply #4 on: October 27, 2014, 10:36:21 am »
[/quote]
Hi John
MeXX
[/quote]
Simply meaning you have the right combination of spring, stress from cam, weight of components and driving skills.
No valve float and not overstressed.
That is pretty cool result for a record breaking car/driver!
Congratulations!
« Reply #5 on: October 28, 2014, 10:51:50 am »
I have heard the PSI springs work longer than k-800 for example. I will try them next year too
Greg G
« Reply #6 on: November 30, 2014, 04:25:25 am »
I have had good luck with PSI springs on my motor. Lots of street miles too.
Elnef
« Reply #7 on: December 03, 2014, 06:24:55 am »
I have bought 2 set psi from MeXX  Smiley
dangerous
« Reply #8 on: December 03, 2014, 21:06:11 pm »
Flat tappet or roller?
Which PSI spring did you choose?
Elnef
« Reply #9 on: December 04, 2014, 06:12:00 am »
Flat tappet
Got this info from MeXX
ISKY 9935 :The quality is superior because they are made by PSI exclusivly for ISKY!
dangerous
« Reply #10 on: December 04, 2014, 09:48:05 am »
I have used those springs and they are brilliant!
I used them for roller cam however.
Shag55
Shag Leone, SL-1racing
« Reply #11 on: December 04, 2014, 17:22:36 pm »
I use the psi 1525 or 1525ml as the replacement for the K-800s
I have been using the 1512ml for a few years now on my street heads. Love them.
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
Jonny Grigg
« Reply #12 on: January 07, 2015, 22:08:18 pm »
What are the specs of the 1525 as I can't find them on the PSI website  Undecided
Would the 1225 be a good replacement for the K800? I am also running 17mm of lift at valve with titanium valves.
Thanks,
Jonny.
No Compromise. O/FF111
« Reply #13 on: January 08, 2015, 12:50:32 pm »
1225 have more coil bind . so you need more installed height than k-800
Shag55
« Reply #14 on: January 09, 2015, 21:27:27 pm »
Sorry. I mis printed. I meant the 1225s
« Reply #15 on: January 12, 2015, 18:14:53 pm »
I have 1225 ML now - do not know the difference to S
Shag55
« Reply #16 on: January 14, 2015, 18:34:43 pm »
Same as std only diffrent heat treat and REM polish
MeXX
« Reply #17 on: February 21, 2015, 11:08:24 am »
Dear Udo
ML option is Maximum Life itīs a surface treatment like polishing and makes them less susceptible for stress cracking...
it was developed for endurance racing like NASCAR. And last but not least the shiny apperance looks really great  Grin Grin
MeXX
Drag or Die
MeXX
« Reply #18 on: February 21, 2015, 11:28:21 am »
Hi Shag
I love them too,and there is a real reason to love them... Grin
The 1525 (ML) is not only a replacement for the K800 itīs just the so much better option.
Because it has a much lower spring ratio of 393 lbs/in but a due to itīs bigger length a higher max lift (.750),
So you can preload them according to your lift to really high seat preassure without extrem nose preassure, helping the valvetrain being lighter and live longer.
Just for compersion
                   CT1225ML                   K800
Desc.                Dual                          Dual
O.D.                  1.445"                  1.460"
I.D. Outer          1.060"                  1.075"
I.D. Inner            .775"                    .782"
Seat Pressure     179lbs@1.850 "   155lbs@1.850 "
Open Pressure   435lbs@1.200 "   480lbs@1.200 "
Rate Lb./In.          393                       450
Retainer Step      .070"                        .070"
Max Lift              .750"                        .700"
Coil Blind            1.100"                    1.085"
MeXX
« Last Edit: February 24, 2015, 22:12:10 pm by MeXX » Logged
Drag or Die
