September 23, 2026, 03:02:43 am
| |-+  For sale!
| | |-+  EMW Q cam, pretty extreme TIV profile
Author Topic: EMW Q cam, pretty extreme TIV profile  (Read 4070 times)
« on: October 27, 2014, 21:43:30 pm »
How about a pretty extreme Q cam on 26 mm base circle.
New.
Data as below.
Not for the anything else than top end horsepower.
T1 lifters and Thorsten Pieper lifter inserts recommended. (You would need to buy from him)
1000SEK or 110 € plus cost for any freight, if applicable.
+46 733361924
fredrik.reichel@tetrapak.com
« Last Edit: October 30, 2014, 07:21:01 am by Frallan » Logged
« Reply #1 on: October 28, 2014, 16:03:38 pm »
Thorsten Pieper inserts.
Fantastic good investment in combination with T1 lifters, that Thorsten also has.
Here is when I installed them on my last engine build.
« Last Edit: October 30, 2014, 07:21:27 am by Frallan » Logged
« Reply #2 on: October 30, 2014, 07:19:43 am »
This ad is only about me selling the cam. Not lifters or inserts.
Thorsten Pieper sells a couple of other nice stuff like 7075 pushrods, lifters, dry sump pump and CNC TIV heads.....not massive production so the product is very personal and the contact the same.
Write to him at thorsten.pieper@gmx.net if you want to know more.
Doktor
« Reply #3 on: October 30, 2014, 13:01:23 pm »
@ Frallan: how much that inserts cost ?  Wink
dr.aircooled
« Reply #4 on: October 30, 2014, 15:00:26 pm »
When I bought them from Thorsten beginning of this year, I paid €50.
I simply warmed each one of my engine blocks halves in my gas BBQ to around 100C according to the ir thermometer, then lifted it in to "my mini mill" or maybe we can call it drill press, prepared with some wooden support to align the block, then drove the lubed inserts in place with a old T1 lifter as drive mandrel.
In my case I had no need for any honing. 7 of them ended up with about 2/100 mm play. I call it hydraulic feeling fit.
One needed a simple touch with 600 grit paper to feel right.
