November 04, 2026, 23:06:28 pm
| | |-+  fuel pump and reg for i.d.a's what are you guys running
Author Topic: fuel pump and reg for i.d.a's what are you guys running  (Read 9238 times)
andy54
« on: November 04, 2014, 23:23:33 pm »
hi
 i just wanted to know what fuel pump and regs you guys are running with 48 i.d.a's. at the moment i am running a 3.5 lb one self regulating from cb.but when my car was on the rolling road as the power was going near the top the fuel pressure was backing way out.so am thinking may need a bigger pump with a reg just wanted to know what you guys are running.my motor is a 2276cc 10\1 comp 44\37 steve tims heads clay smith cam like a fk89..
thanks for any info.
cheers andy
K-Roc
« Reply #1 on: November 05, 2014, 00:28:13 am »
What size of fuel line, front to back?
also is your inlet Needle/ seat still a 2.0 ?
« Reply #2 on: November 05, 2014, 00:58:04 am »
Have the float bowls been opened up to maximum? if not that will help as well
2332-64
« Reply #3 on: November 05, 2014, 13:04:18 pm »
hi
cheers andy
I’m running a similar-ish engine spec to you and using the CB rotary pump.
I have a separate fuel hard line feeding the pump/carbs and my float bowls have been enlarged – never had any problems with fuel starvation on the strip or street.
2332cc FK89 48IDA
12.8 @ 102.8 mph. Full weight bug - all steel, interior, glass, belt, treads and muffler.
0-60 3.99 secs
Erlend / bug66
Global Moderator
SCC Event
« Reply #4 on: November 05, 2014, 13:14:49 pm »
Holley black pump and aeromotive A1000 carb return regulator here.
AN8 both ways.
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Joe Bence
« Reply #5 on: November 05, 2014, 19:45:10 pm »
Holley red pump and matching reg  -6AN front to back
andy54
« Reply #6 on: November 05, 2014, 20:01:03 pm »
hi guys thanks for the input
the fuel line from the tank that goes to through the car is bigger than stock think its 8mm but this was done way back in 06 when i first brought the car..so not too sure.. the out let in the  fuel tank is -6an the one cb sells. the needles are still the stock ones that come with the i.d.a's 2.0
the float bowls are stock the only modds to the carbs are 3rd progression hole and jpm 42mm vents and jpm stacks.the fuel lines for the reg and the carbs are all -6an
i had a 2007 with a k8 cam 9\1 com 42\37 heads and never had any fuel problems with the pump set up i have.the reg{holly} never worked too well with  so had the insides taken out so now its just a flash t pice..
so what do you think should i get just the float bowls made bigger ?? or just a bigger pump and reg??? or both...
thanks for your help with this guys..
« Last Edit: November 05, 2014, 20:03:23 pm by andy54 » Logged
« Reply #7 on: November 06, 2014, 01:17:03 am »
Get the float bowls done, then you are less likely to run out of fuel to begin with, and also check if the tank still has the stock filter gauze in place, it might be full of crud by now
K-Roc
« Reply #8 on: November 06, 2014, 06:49:19 am »
3.0's wouldn't hurt either.    Wink
stealth67vw
« Reply #9 on: November 06, 2014, 07:07:01 am »
I'm running a Mallory 4070LP (super quiet) with no regulator on my IDA'd 2165cc hot street engine. Stock 2.0 needle, float bowls and fuel inlets opened up, AN -6 and 3/8" solid line from tank. I also have Mallory fuel filter, no stock style screen. Fuel pressure is solid at 3.5 pounds at the carb tee.
« Last Edit: November 06, 2014, 07:08:40 am by stealth67vw » Logged
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
andy54
« Reply #10 on: November 06, 2014, 21:44:50 pm »
k-roc i have a pair of the glass needles that jaycee sells think they are 3.0 we could not get them to work on the last motor they just flooded the carbs...
hi richie do you know anyone in the uk that can do this mod??? i am pretty sure the gauze in the tank is long gone as there is the -6 fitting in there now.
cheers andy
« Last Edit: November 06, 2014, 21:49:41 pm by andy54 » Logged
andy54
« Reply #11 on: November 06, 2014, 21:47:43 pm »
thanks for that may look into this pump do you know if you can run a reg with this pump.when you say fuel inlets opened up do you mean the -6 fitting straight into the top??
thanks for your info on this..
cheers andy
« Reply #12 on: November 07, 2014, 01:16:07 am »
cheers andy
Most of the adaptor fittings I have seen or used still need a seal, and alot of people use the stock gauze with seal to work so it might be in there still
Its quite simple to open the float bowl up, if you take the top of and look it has a wall with an extra chamber that is dry, this wall is machined away to open up the float bowl bigger, I will see if I got a before and after pic and post it up if I find them
stealth67vw
« Reply #13 on: November 07, 2014, 01:16:33 am »
Yes, AN -6 into tops but the inlets in the carb tops are also drilled out to 5/16" where the fuel screen would go.
John Bates
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
stealth67vw
« Reply #14 on: November 07, 2014, 01:18:54 am »
I have pics of my float bowls opened up. I used a .250 endmill on my Bridgeport and plunged straight down. sorry about the big pics. Undecided
Before:
After:
John Bates
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
andy54
« Reply #15 on: November 07, 2014, 19:08:40 pm »
hi john thanks for the pics of the float bowls....
richie do you do think just do the mod on the float bowls or would you put a bigger fuel pump and reg on as well?? the pump i am running at the moment is a cb 3.5lb self reg one
will have to ask james if he can do this mod for me. i thought all this was just for the big boys lol....thanks for your help and info on this.
andy
