September 22, 2026, 04:04:24 am
| | |-+  Pics of lookers on 14" fuchs?
Author Topic: Pics of lookers on 14" fuchs?  (Read 16458 times)
Jos
« on: November 07, 2014, 07:45:34 am »
I've got a set of 14" Fuchs in the garage and wanted to see if anyone has pictures of them on an old school looker. Are there any iconic cars that ran staggered 14" and 15" rears?
If they won't look right I'd like to get them in the hands of an early 912 or 911t owner and keep looking for a set of 15"s (these are so much more budget friendly though.)
xavier
« Reply #1 on: November 07, 2014, 18:28:46 pm »
Look at this topic
Xavier
http://cal-look.no/lounge/index.php/topic,16962.msg246003.html#msg246003
Jos
« Reply #2 on: November 07, 2014, 18:30:11 pm »
Thanks Xavier! I did a searc but didn't come up with that. I guess I wasn't using the right terms
xavier
« Reply #3 on: November 07, 2014, 18:33:00 pm »
Another car on 14 fuchs
http://cal-look.no/lounge/index.php/topic,20665.0.html
xavier
« Reply #4 on: November 07, 2014, 18:38:01 pm »
Frenchy's Ghia was also on 14" Fuchs
56BLITZ
« Reply #5 on: November 08, 2014, 00:14:19 am »
My '70 is not iconic, but I have been driving it everyday with 14" & 15" alloys . . . front tires are 175/65 R 14 . . . . rear tires are 165/80 R 15 . . . . turns and stops fine.
I will replace the rear tires with a larger size at some point.
I have my adjusters quite low . . . the only thing that drags on occasion is the stock anti-roll bar.
It still has drum brakes all the way around.
LMK if ya want to see a photo.
Jesucristo es mi Seņor y Salvador!
Jos
« Reply #6 on: November 08, 2014, 01:38:27 am »
Of course I'd love to see photos! It's never too late to become iconic Smiley
56BLITZ
« Reply #7 on: November 08, 2014, 09:25:27 am »
« Last Edit: November 08, 2014, 10:36:53 am by 56BLITZ » Logged
Jos
« Reply #8 on: November 08, 2014, 16:13:05 pm »
Real cool! A '70? Looks very similar to what my '68 will sit like with them on there. (only my '68 is red)
56BLITZ
« Reply #9 on: November 08, 2014, 17:54:22 pm »
Thanks! I really enjoy driving it!
I need to get some spacers (10mm?) for the back along with grinding the end of the axles in order to fit center caps.
I think it would look better with larger tires in the rear . . . . maybe 195/70 R 15
Post pics of yours when you are able, ok?
« Reply #10 on: November 08, 2014, 21:59:52 pm »
Only thing that sucks about 14's on the front is you can't use drop spindles Undecided
Jos
« Reply #11 on: November 08, 2014, 22:26:42 pm »
I noticed that in the other post. Is it possible to shave down the spindle some or where is the interference?
« Reply #12 on: November 09, 2014, 01:56:04 am »
Sits nice Mrk
« Reply #13 on: November 09, 2014, 06:52:09 am »
On the bottom ball joint. Some 15" wheels require a little shave to the ball joint, I don't think there's any easy way you'd get a 14" to fit.
team97
3M TA3
« Reply #14 on: November 10, 2014, 20:59:19 pm »
Jim Moore's Notch was on 14's, then I put 15's on it.
Der Kleiner Panzers III
D.K.K.
Larry S
« Reply #15 on: November 11, 2014, 04:22:06 am »
Here is my old oval circa 1983 with 14" alloys on it.
DWL_Puavo
« Reply #16 on: November 11, 2014, 13:11:31 pm »
Jos - or any other else having 14" original fuchs - could you please weigh them as I can't find their weight from any of the usual lists.
EDIT: Thanks a lot Jos, and for us non-imperialistics - 11lbs is just 5kg.
Puavo
« Last Edit: November 12, 2014, 11:34:09 am by DWL_Puavo » Logged
Jos
« Reply #17 on: November 11, 2014, 16:44:02 pm »
I just weighed one and it was 11lbs. exactly.
youngnstudly
« Reply #18 on: November 12, 2014, 08:35:45 am »
I have a set of 14" Fuchs for my bug that hopefully I can install sometime next year. They are still in decent shape with the anodizing not worn through, so maybe I can just repaint the black areas of the rims in satin black...and find 2 more center caps. The 14's are supposed to fit a link pin front beam with dropped spindles, according to a few on the samba. Fingers crossed.
@Larry S, do you recall what size tires you were running on your 14's? I realize it was over 31 years ago, so no worries if you don't remember.  Wink
Thanks,
Andy
Dave Rosique
nobodyouno
« Reply #19 on: November 12, 2014, 16:45:56 pm »
Thanks,
Andy
Yes, 14" will fit a link pin with dropped spindles.
My Oval project.. 14" with F-560 front, 15" with M&H rear.
Dave Rosique
nobodyouno
« Reply #20 on: November 12, 2014, 16:54:49 pm »
forgot to add, mine are 155R14 from Coker Tire.
56BLITZ
« Reply #21 on: November 12, 2014, 23:39:46 pm »
It seems to me that the selection of 14" tire sizes has improved since the eighties.
Dave, yer car is lookin' GOOD!
Larry, your car looked great also!
« Last Edit: November 12, 2014, 23:41:38 pm by 56BLITZ » Logged
« Reply #22 on: November 13, 2014, 02:02:53 am »
That looks good. I've got a set of 14's & 15's, was planning on running a 175/70 up front. It will fit the wheel perfectly, and be only a tad shorter than a 145/15.
youngnstudly
« Reply #23 on: November 13, 2014, 03:45:44 am »
That looks great! Thanks for the info Dave!  Smiley
I can't believe the pricing on some of the 14" tires. I was looking last night online and you can get some decent (name brand) rubber for as little as $45 per tire, depending on where you look. Of course you can probably get a $145 tire if you wanted to as well. I was surprised at the selection of tires that cost $50-65, when I'm used to paying $80-100 per tire for 15's.
« Last Edit: November 13, 2014, 03:47:38 am by youngnstudly » Logged
Dave Rosique
nobodyouno
« Reply #24 on: November 14, 2014, 20:48:19 pm »
I'm happy with the look of 14's & 15's (see below)
For the record, 155R14 is only slightly taller than a 135R15
« Last Edit: November 14, 2014, 20:49:58 pm by Dave Rosique » Logged
Jos
« Reply #25 on: November 14, 2014, 21:05:52 pm »
I love the contributions so far guys! Makes me grateful to not have to spend 4k to have a nice set or rims Smiley I agree with you Dave, that combo works really well on VWs
Larry S
« Reply #26 on: November 16, 2014, 16:55:30 pm »
Dave, I don't remember the size of the tires, I think 145's up front, I do remember they were michelins, seemed to last forever and I used them like a $2 whore.....
56BLITZ
« Reply #27 on: November 17, 2014, 03:57:44 am »
Hey Dave, those are the M&H P215/65-15, correct?
Dave Rosique
nobodyouno
« Reply #28 on: November 17, 2014, 06:24:36 am »
Correct!
