November 03, 2026, 01:49:42 am
| | |-+  another 67--- Finished
Pages: 1 [2] 3 Print
Author Topic: another 67--- Finished  (Read 50521 times)
karl h
« Reply #30 on: December 28, 2014, 10:42:03 am »
I've done the other side of that panel recently, put the hinge mounts and vents back in. Arse of a job, isn't it!  Cheesy
you can say that again! i welded it on the bottom first, then bended it inward to get primer to the welded area inside, bended it back and then did the lip.
nice job on the vents.
« Last Edit: December 28, 2014, 20:53:33 pm by karl h » Logged
karl h
« Reply #31 on: December 31, 2014, 17:02:59 pm »
at first i thought i can save the passenger side heaterchanel, but it turned out to be more work than it was worth. so i welded in the bars to keep everything aligned and started to cut out the chanel
stay tuned
karl h
« Reply #32 on: January 10, 2015, 13:08:08 pm »
passenger side is in Tongue
just some more welding on the firewall and spare tire well and the body is done
smurf67
« Reply #33 on: January 13, 2015, 21:55:37 pm »
Looking good, and moving quicker than my 67 project. Out of interest I don't suppose you still have the heater channel vent from the driver side do you? If so would you sell it? I have the sliding door part etc just need an original vent for behind it. Cheers Alex
karl h
« Reply #34 on: January 14, 2015, 07:36:42 am »
both cut out heater chanels are still in the trailer (to be hauled to the trash), i can take a look. but i think the drivers side vent crumbled because it was rusted apart on the bottom. the passenger side one is fine, you can have that. maybe it can be used on the left side? i, on the other hand, am missing the sliding part on the drivers side.
smurf67
« Reply #35 on: January 14, 2015, 08:36:34 am »
Hi Karl if you have either side that would be great I'm sure I can work something out so it fits Smiley I may have a spare door at the workshop  my car is at unfortunately I won't be there again for a week or two now but if I find it your more than welcome to it. Cheers Alex
karl h
« Reply #36 on: January 17, 2015, 14:11:13 pm »
i have finished welding the body, the doors and fenders are next to be prepped. i talked to the painter and told him i will drop off the car in the last week of january
all of the undercoating has been scrapped off manually, even underthe tank area  Tongue
karl h
« Reply #37 on: January 17, 2015, 14:19:32 pm »
engine compartment has been taken care of too
next step epoxy primer
« Last Edit: January 17, 2015, 14:21:40 pm by karl h » Logged
karl h
« Reply #38 on: January 21, 2015, 21:04:01 pm »
more boring bodywork   Tongue
Good-Old-Ragtop60
« Reply #39 on: January 22, 2015, 08:55:57 am »
You`re making good Progress!  Smiley
I can`t wait to see more.
Cornpanzer
« Reply #40 on: January 25, 2015, 03:02:45 am »
Very nice buddy!
'67 Turbo Sedan
Ultra VW Contributor
karl h
« Reply #41 on: January 25, 2015, 21:13:47 pm »
thanx guys!
hey dave, whats up?
the lower parts have been coated with epoxy primer now, body is ready for the paintshop. i have started on the doors and fenders. dont think i will make it till friday Tongue
karl h
« Reply #42 on: February 02, 2015, 21:16:02 pm »
ran out of bondo, so i started on the pan. some welding to do on the framehead and the left rear pan.
workshop is pretty crowded, as it snows outside and i dont want to get the body wet
karl h
« Reply #43 on: February 04, 2015, 22:03:52 pm »
going to drop off the body at the paintshop tomorrow morning  Cool
« Reply #44 on: February 05, 2015, 11:14:44 am »
Great progress. Going to be a cool car Smiley
karl h
« Reply #45 on: February 17, 2015, 12:34:28 pm »
in the meanwhile i turned my attention to the pan
i had hoped it was in a better shape that is really is Tongue
so after some colourfull words i cut out the panhalves
sorry for the bad pics
karl h
« Reply #46 on: February 17, 2015, 12:38:18 pm »
the lower framhead and the napoleon hat will be replaced too.
if you need the replace the latter be very carefull that the stamping of the repairpiece has the same height as stock, or else the body wont fit (thanx for telling me that, Alfred!). i will only use the lower part and keep the stock upper curvature
karl h
« Reply #47 on: February 18, 2015, 10:41:38 am »
 Grin Grin Grin
jamiep_jamiep
« Reply #48 on: February 19, 2015, 10:23:57 am »
Wow that looks amazong Karl, you must be over the moon with it!
karl h
« Reply #49 on: February 19, 2015, 11:13:23 am »
pretty happy with the paintjob.
cant say that for the pan, the framehead is in catastrophic shape. dont want to use one of the aftermarket units, only bad things are heard of these...
« Last Edit: February 26, 2015, 11:25:42 am by karl h » Logged
thehanz DVK
« Reply #50 on: February 20, 2015, 12:50:18 pm »
aahh looking good, another nice 67 in the works...wil you be at the eurobug -in ?
karl h
« Reply #51 on: February 26, 2015, 10:05:06 am »
no bug-in for me, just too far to drive and i´m not sure the car will be finished Tongue
more work done on the framehead. i replaced the lower 10cm with a donour piece (thanx again, Alfred). with the beam bolted up to the upper part you can get the lower part dead-on without any danger of misalignement. careful fitting is in order to line everything up nontheless
karl h
« Reply #52 on: February 28, 2015, 22:14:27 pm »
work on the pans is nearly complete
karl h
« Reply #53 on: March 09, 2015, 08:04:31 am »
coated the new halves with epoxy primer and black chassis paint. over the weekend i put in new brake lines, the MC and the pedal assembly.
karl h
« Reply #54 on: March 27, 2015, 19:07:49 pm »
pan is a roller now
going to have marriage tomorrow Grin
karl h
« Reply #55 on: March 28, 2015, 19:29:40 pm »
wedding was cool Grin
photos courtesy of my friend Alfred. He, bodyman Stefan and my stepson Christian had the body on the pan in 30 seconds
before:
karl h
« Reply #56 on: March 28, 2015, 19:33:12 pm »
and after. had a beer, but then i spent the rest of the afternoon having fun with the bolts
karl h
« Reply #57 on: April 06, 2015, 09:32:40 am »
started on the wiring and dash
« Reply #58 on: April 06, 2015, 18:24:08 pm »
You are pretty fast , nice car :-)
Stevo_L
« Reply #59 on: April 06, 2015, 18:53:28 pm »
nice car but are you leaving the front end and it's rusty parts or will it be changed?
