October 15, 2026, 08:40:10 am
| | |-+  torsion bar recommendations irs bug
Author Topic: torsion bar recommendations irs bug  (Read 4592 times)
baz
« on: December 02, 2014, 10:14:46 am »
Hi I'm trying to figure out which torsion bars to fit my bug, it's an irs rear end,  street car with 2276.  I'd like to run short bars 21 and something inches as I'd like to lose the snout in the rear wheel wells. I've heard irs cars don't require as much extra spring as a swing axle and was thinking maybe 25mm bars would suit,  can anyone advise on what would be best size to use and if there is any reason not to use short bars in an irs car.
I will prevail.
« Reply #1 on: December 02, 2014, 18:06:40 pm »
Hi Baz
As long as you get the correct spring plates you can use the short bars, I do, I typically use 26mm short bars on full weight street cars but 25mm would work fine, just make sure you get a decent shock to control it
« Reply #2 on: December 02, 2014, 18:09:58 pm »
Nice thread . where are torrosoin bars avaliable ? i need 26 short ones too ....
baz
« Reply #3 on: December 02, 2014, 19:56:06 pm »
Thanks ritchie, I knew someone on here would be running short bars and plates.
Udo, irs bars are available up to 25mm I think from porsche 944 turbo, also irs type 3 squareback has 24.5 bars
For heavy duty short bars sway away do them
I will prevail.
« Reply #4 on: December 02, 2014, 20:03:06 pm »
Hi Udo
CB and Bugpack sell them
« Reply #5 on: December 03, 2014, 08:02:20 am »
I know but need short ones.
Richie - i  know about bugpack - but nothing in stock . i can ask Pat at CB
baz
« Reply #6 on: December 03, 2014, 08:24:13 am »
Csp sell the sway aways, coolair in uk also list them
I will prevail.
