September 22, 2026, 18:15:35 pm
| |-+  Wanted
| | |-+  key for pre 67 collumn lock
Author Topic: key for pre 67 collumn lock  (Read 8079 times)
beetletom
« on: December 10, 2014, 17:11:42 pm »
any ideas what key is used for a pre 67 beetle column lock and ignition?
thanks.
« Reply #1 on: December 10, 2014, 21:17:15 pm »
A normal dash type.....
That what my 65 & 66 had  Undecided
beetletom
« Reply #2 on: December 15, 2014, 17:18:59 pm »
tried some original 60's vw keys i had laying around, they are physically too big to fit into the key hole
the joys of owning a car with no keys for it!  Lips Sealed
Jim M
« Reply #3 on: December 19, 2014, 00:06:26 am »
can u post a picture of the lock?
Porters Precision
« Reply #4 on: December 19, 2014, 11:51:57 am »
There is a guy on volkszone who "Re-Keys" all vw locks......
Not sure he will be able to help if this is an "Aftermarket" coloum lock, you will need to make a key "fit" the lock-waffles because I am pretty sure you will not be able to get "Spares"  Undecided
beetletom
« Reply #5 on: December 20, 2014, 10:47:40 am »
i'll try and get a pic.
yep i think that may be the case! Sad
dragvw2180
« Reply #6 on: December 21, 2014, 02:38:36 am »
 I have one on my 66 , I will compare it to some bug keys I have tomorrow . I may try to have it copied if it would help you. Mike McCarthy
beetletom
« Reply #7 on: December 22, 2014, 13:07:37 pm »
thanks!
beetletom
« Reply #8 on: January 05, 2015, 18:03:08 pm »
took this out of the car the other day
the locking column bit has been removed in the past (not too bothered about that)
found out why the key wont go in, as part of the tumblers inside, have moved across the keyhole, so the key won't go in!
any ideas how to remove the lock assembly, from the housing?
looks like there is a screw or a rivet (but someone has drilled the head off...)  Angry
« Reply #9 on: January 07, 2015, 19:46:17 pm »
Dude sound like you should forget this one....
Sounds like a mess  Undecided
Find a NoS item with the key, Probably not that hard these days.....
beetletom
« Reply #10 on: January 07, 2015, 20:27:12 pm »
yeah! Sad
they are quite hard to come across in the uk
but like you said, should be ok to find on the internet
but the ones i've seen advertised are big £££
do you come across any where you are?
« Reply #11 on: January 07, 2015, 21:03:54 pm »
What in WATFORD hahahahaha I am back in the UK......
I am SURE you can find a "Good one"  Undecided
beetletom
« Reply #12 on: January 07, 2015, 21:06:58 pm »
ah! thought you were still in norway (or finland or somewhere lol)
