September 15, 2026, 21:29:55 pm
Latest Member: Bad Habit
| | |-+  Torque sequence for body to pan !!!
Author Topic: Torque sequence for body to pan !!!  (Read 6118 times)
Frenchy Dehoux
« on: December 12, 2014, 23:25:04 pm »
   I am looking for the proper torque sequence when bolting the body to the pan ( Beetle ). And what is the torque on the pan bolts. If there is a factory book or bulletin I can down load.
Frenchy
Doctor Detail ( Retired )
« Reply #1 on: December 13, 2014, 03:12:34 am »
Gudentite.
spoolin70
« Reply #2 on: December 13, 2014, 14:34:28 pm »
Kinard
Lanny Hussey
« Reply #3 on: December 13, 2014, 16:44:53 pm »
I've always wondered if there was a sequence.
According to generic tables, M8 grade 8.8 bolts are around 24NM, M10's around 47NM.
I'm sure you (Frenchy) are aware of the importance of the rubber spacers under the beam and rear torsions. If these are too thick, which many aftermarket versions are, the body can end up severely distorted after everything is tightened down. Years ago, I did body/paint on a show quality 57 Oval. The customer picked up the painted shell and took it home to mate up to the restored pan. Later, the distressed owner called me and suggested I had 'bent' the body shell. Once I saw the car, and the drivers door hanging  1" below the opening I checked the rubbers under the rear seat and beam top. It had the 5/8" thick versions, which don't fit anything VW I've seen. He had tightened the bolts along the pan sides with an impact. Shocked Hope this helps.
Frenchy Dehoux
« Reply #4 on: December 13, 2014, 17:03:50 pm »
   Lanny thanks for the update I knew about the rubber pads if to tight will distort the body as you mentioned. I remember somewhere I had see the torque sequence.
Thanks for the help
Frenchy
Lanny Hussey
« Reply #5 on: December 13, 2014, 17:12:50 pm »
Happy Birthday.. Cheesy
« Reply #6 on: December 13, 2014, 20:47:23 pm »
how thick should they be? Smiley
Frenchy Dehoux
« Reply #7 on: December 14, 2014, 08:09:44 am »
    Thanks Lanny !!!!
Frenchy
Brian Silva
« Reply #8 on: December 20, 2014, 04:26:48 am »
Hi Frenchy,
Here is the sequence from the factory Manual. Cheers!
Let me know if more info is needed.
Frenchy Dehoux
« Reply #9 on: December 22, 2014, 16:11:00 pm »
  Thanks Brian.
Frenchy
