September 24, 2026, 04:59:28 am
| | |-+  Getting ready to convert to short axles on my 67 and have a few questions
Author Topic: Getting ready to convert to short axles on my 67 and have a few questions  (Read 9291 times)
Matt Tobias
« on: December 15, 2014, 03:11:46 am »
Hello!  Getting ready to tuck my wheels under my fenders by switching to short axles.  Does anyone of any good online tutorials to follow?
Are there any kits you can buy for setting up the endplay on the axle that include gaskets?
Which bearing/oil seal retainer will I need for the end bearing inside the drum?
Thanks!!
Matt
deano
« Reply #1 on: December 15, 2014, 04:43:32 am »
Just a couple of pointers. First, the axle tubes are the same, just the shock/end castings are different. Since '67s use long axles with short splines, your new shorter axles will also have "short" splines. So, the drum snouts are the same.
Anglia Obsolete Guru
'67 Heaven
56BLITZ
« Reply #2 on: December 17, 2014, 04:24:43 am »
You should be fine with '67 bearing retainers and matching spacers. Do not use pre '63 bearing retainers . . . they don't have the "weep holes" in them.
when you have the "short" tubes, you can compare the depth where the bearing sits in the end casting with that of your '67 axle tubes to make sure that they are the same.
There was a change in '68 end castings/bearing retainers/spacers, so be sure to check! Look here for photos . . . http://www.thesamba.com/vw/forum/viewtopic.php?t=583865&highlight=axle
PS . . . I'm talking about U.S. cars . . . do not know if Euro stuff is the same!
« Last Edit: December 17, 2014, 04:26:23 am by 56BLITZ » Logged
Jesucristo es mi Seņor y Salvador!
« Reply #3 on: December 17, 2014, 18:22:04 pm »
Search on here. There was a hot vws article about this which was scanned and uploaded
« Reply #4 on: December 17, 2014, 21:11:23 pm »
I'm going to be doing something similar over Christmas if I get chance. Got a '72 swingaxle box with long axles and Porsche pattern drums, and a '66 short axle box. I want to put the short axles on the later box with the Porsche pattern drums to fit 7" Cookie Cutters under stock rear wings. I think some machining will be needed...
56BLITZ
« Reply #5 on: December 18, 2014, 00:10:07 am »
To the hub on the drum.
As an aside . . . on my '68 Ghia . . . when I used the short axles to fit my 15X6 Porsche alloys, I need spacers ( 10mm . . . IIRC ) in order to keep the tires from rubbing on the body mount.
Matt Tobias
« Reply #6 on: December 18, 2014, 00:46:41 am »
Thanks for all the info everybody!  I will look for that article.
nlvtinman
« Reply #7 on: December 18, 2014, 01:06:19 am »
As Neil alerts to, you do have to machine the bolt surface on the drums. I had to do such when I installed type 3 brakes on the short axle trans in my '67 sedan.
Dougy Dee
« Reply #8 on: December 18, 2014, 02:20:03 am »
You machine 5/8" or .625 from the snout of the drum.
« Reply #9 on: December 18, 2014, 02:23:57 am »
Just to be clear. It's the surface where the axle nut contacts the drum that needs to be machined. Wink
I went through this when I converted my '67 to 4-lug.
Still gotta do the short axle conversion.
« Reply #10 on: December 18, 2014, 03:04:15 am »
We used short axles with 7" cookie cutters and 215/65's on Asshull's 67. No clearance issues. Only difference was CB disc brakes.
neil68
« Reply #11 on: December 18, 2014, 07:23:01 am »
I saw the tire photo in your build thread and yes, '66 short axles should solve your problem.  I run 6" CMS wheels with M&H DOT street-strip tires in the 215/65 size and the short axles help the rubber to just barely clear the fenders (wings) with 3.5" backspacing.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Matt Tobias
« Reply #12 on: December 18, 2014, 07:35:26 am »
Thanks Neil!
Jimbo01
« Reply #13 on: December 18, 2014, 19:00:10 pm »
All good info on "How To". To help you see what it will look like when you are done, here is a picture of my recently completed 67. It has short axles with Flat Four Enkei 5 spokes. Brakes are CB disc which push out the wheels 1/8 inch.
Jimbo
« Last Edit: December 18, 2014, 21:14:55 pm by Jimbo01 » Logged
RichardinNZ
« Reply #14 on: December 18, 2014, 21:35:36 pm »
Jimbo
It seems to me that you should be posting some more pictures of your car....looking good.
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
