August 13, 2026, 09:25:58 am
QA1 shocks
Topic: QA1 shocks (Read 9999 times)
Ninho/DKM
QA1 shocks
December 27, 2014, 01:11:35 am »
Could someone write me which QA1 shocks are right for a standard mounts on a 63 pan? Extended and compressed lenght and or serial code, just to identify which could be right to buy. Thanks to all.
1974 Superbeetle Porsche affected and influenced
1957 Gasser Project work in progress
1973 Thing type 181 Civil version (sold)
1959 Bug waiting attentions
1963 Surfin'Bird Street and Strip race Bug 1776cc Best E/T 14,769 at Hills Race#10
www.Surfinbirdbug.blogspot.it
www.Ninho-Reloaded.blogspot.it
Re: QA1 shocks
December 27, 2014, 11:16:44 am »
Rears? from memory this one
http://www.jegs.com/i/QA1/122/TS403/10002/-1
You need to swap out the steel sleeves they supply for metric ones to fit the vw size bolts, I have just pressed them out of old vw shocks before to use and pressed them in the QA1's
Last Edit: January 20, 2015, 18:14:59 pm by richie
Ninho/DKM
Re: QA1 shocks
January 02, 2015, 00:53:33 am »
Many thanks Richie!!!
And do you think this:
http://www.jegs.com/i/QA1/122/DD402/10002/-1
Could be ok too??
Last Edit: January 02, 2015, 00:56:35 am by Ninho/DKM
Re: QA1 shocks
January 02, 2015, 09:10:55 am »
Are you wanting a coil over then? it would be ok length wise, but not so easy to fit as its pysically bigger, if you go coil over I would get double adjustables, not singles
Ninho/DKM
Re: QA1 shocks
January 03, 2015, 01:30:10 am »
Oh, ok. I will consider. Many thanks again!!
hotstreetvw
Re: QA1 shocks
January 15, 2015, 05:13:31 am »
How do you guys run limiter straps with the QA1 adjustable shocks?
Re: QA1 shocks
January 15, 2015, 09:38:29 am »
Quote from: hotstreetvw on January 15, 2015, 05:13:31 am
I use longer mounting bolts, then a spacer[cut down piece of tube that fits tight over bolt] between shock and limit strap to allow clearance, you could just use thick washers & stack them on the longer bolts
hotstreetvw
Re: QA1 shocks
January 15, 2015, 16:23:24 pm »
[ Attachment: You are not allowed to view attachments ] Thanks Riche.
My car has a narrowed torsion housing with the stock shock mounts cut off. I have a sub frame above the torsion bars that I will use for the shock mounts. I think what I will end up doing is running the strap from the outside of the axle tube shock mount, up to a separate strap mount on the subframe. Sort of what Mike did here on the bottom mount.
http://mufflermike.com/motortech.html
scroll 5/8 down the page.
My concern was the mount + shock + spacer, then strap! would make for a long bolt and high bending moment. I can't avoid it because the tube mount is outward of the shock and the sub frame mount inward. Not sure if that is clear. Putting the strap on the spring plate side should help.
QT VW
Re: QA1 shocks
January 18, 2015, 22:34:18 pm »
Would these QA1 shock's be good in a street strip beetle , running berg 5 and 2276 cc
Re: QA1 shocks
January 19, 2015, 11:15:11 am »
Quote from: QT VW on January 18, 2015, 22:34:18 pm
I have them on a couple of street cars that also see the track and they work good
