September 24, 2026, 17:31:06 pm
New OEM 356/912 gen pulleys, dark brown 010 dist caps + MORE
Topic: New OEM 356/912 gen pulleys, dark brown 010 dist caps + MORE (Read 9965 times)
January 22, 2015, 00:44:44 am »
NEW Web 86B type 1 cam with unknown-brand new lifters. No box, but have cam card. $120 for the set, plus shipping. Want hand fitted dual thrust bearings with oiling mod with it? Let me know, Mahle Brazil for $26.00 or Glyco with copper face thrust surfaces for $44.00, plus shipping. Firm pricing on this stuff.
"Looks new" Melling oil pump for type 1, no cover, $25.00 plus shipping
New FK89 Engle and Bugpack race lightweight lifters, $160.00 plus shipping
Porsche 356/912 generator pulley halves, hubs and nuts, all new OEM:
please note, these may or may not be gold cad plated... the gold cad is being phased out by many suppliers, may ship zinc plated
Inner half: $22.00 plus shipping
Outer half: $22.00 plus shipping
Hub: $30.00 plus shipping
36mm nut, GENUINE new: $46.00 plus shipping
OEM 911 swivel foot 8mm adjuster screws, not overseas copycat, the real OEM item: $22.00 ea plus shipping (locknut not included)
Daikin-Exedy 200mm metal-woven Type 1 clutch discs: $72.00 plus shipping
Dark brown distributor cap, German, for 010, 019 022 etc cast iron Bosch distributors: $19.00 plus shipping
Schadeck 26mm new oil pumps, modded for full flow and increased volume, $55.00 plus shipping
Schadeck 30mm new oil pumps, modded for full flow and increased volume $55.00 plus shipping
(on the oil pumps, if I do not have them in stock, there may be a 4-5 day delay before I ship. I will also email you instructions on oil pump install in PDF format)
NGK Iridium plugs for your big Weber carb'd street motor, most thread sizes and heat ranges available. Tested these in several street cars in last 5-6 years and difference in "forgiveness" in tuning big Webers using these vs copper plugs is "Night and Day". Hard to believe how well these run. Inquire with your needs.
Please PM me.
Last Edit: March 06, 2015, 18:40:23 pm by Jim Ratto
Re: Misc HP engine stuff for sale: some new, some used; UPDATED WITH MORE ITEMS
January 26, 2015, 21:31:41 pm »
Used Holley Red pump and low pressure regulator
(sold 1-26-2015)
Want your VW heads set up to your cam? I can shim springs, set installed height and hand fit keepers/retainers for maximum life. Please inquire with your needs
Last Edit: January 27, 2015, 19:30:25 pm by Jim Ratto
February 02, 2015, 17:41:03 pm »
Joe Gibbs camshaft/lifter lubricant- $7.00 tube plus shipping
Last Edit: March 06, 2015, 18:40:52 pm by Jim Ratto
February 03, 2015, 22:03:52 pm »
Type 1 main bearings,
steel backed # 2 shells
, most sizes: $38.00
Type 1/2/3 13-1600cc Elring gasket kits, with good flywheel seal: $18.00
KS VW journal rod bearings: $16.00, std and most undersizes
German "Porsche" points for 010, 019 distributor: $9.00
OEM ignition condenser for 010, 019 distributor $10.00
7100-RPM or 7300-RPM cutoff rotor for 009 Bosch: $35.00 (RPM limiting rotor)
German, OEM-style ignition wire set, works better than stock with dual carburetors, solid-core, with correct connectors and air-seals: $48.00 (these look like factory, perfect for correct and original appearance).
HD gold-cad plated 8mm x 1.25 socket head bolt, works great in places like bumper brackets, over-rider tubes, etc. Approx 4" in length: $3.00 ea
Hazet fold-out-tray portable tool box, 190L. Folds out, 2 trays per side. Super rugged, blue enameled. German cars deserve German tools. $120.00
(ask me about other Hazet tools and tool accessories)
all items subject to shipping charges, depending on order and destination.
Please PM me if you have questions.
Last Edit: February 04, 2015, 05:05:36 am by Jim Ratto
February 09, 2015, 18:23:42 pm »
Did I mention we do Weber? Parts, calibration stuff, and advice. We can help.
Re: New OEM 356/912 gen pulleys, dark brown 010 dist caps + MORE
February 18, 2015, 05:08:21 am »
Bosch OEM rotors for 010, 019 $19.00 plus shipping
pupjoint
February 22, 2015, 15:51:52 pm »
you have pm
pupjoint
February 27, 2015, 07:12:08 am »
jim, you have pm and email.
March 17, 2015, 22:50:08 pm »
912 pulley nuts are low stock right now, more coming soon. Just FYI
Rocket Ron
It's old school for a reason
April 01, 2015, 12:48:58 pm »
Pulley Arrived today thank Jim
Top quality stuff
13.12 @ 101.84
Grooving out on life
April 04, 2015, 01:10:58 am »
Quote from: Ron Elliot on April 01, 2015, 12:48:58 pm
Top quality stuff
Right on... glad you're happy!
April 20, 2015, 23:48:30 pm »
More stuff on special through April.....
http://www.thesamba.com/vw/classifieds/search.php?username=partsfast
Thank you,
Jim
May 26, 2015, 02:46:18 am »
bump
