September 22, 2026, 17:21:24 pm
| | |-+  JPM head drilled to 101.6 (stud pattern question)
Author Topic: JPM head drilled to 101.6 (stud pattern question)  (Read 6482 times)
fastbus
« on: January 24, 2015, 07:01:05 am »
Hi Loungers,
                 I'm slowly building an oxyboxer and i'm planning on using a set of JPM heads which look like they have 94mm stud pattern spacings.
These heads have been apparently cut for the 101.6 cylinder liners and are now showing through on the the stud inserts, where the liners meet the chamber in the heads.
Is this common practice or should the stud spacings have be drilled from a blank head to accept the correct pattern?
Any helpful and grateful advice is appreciated.
Paul
 Wink
« Last Edit: January 24, 2015, 07:06:00 am by fastbus » Logged
13.66@102mph in my old T3 crew cab builders truck!
13.01@109mph in my bug so far!
« Reply #1 on: January 24, 2015, 09:18:41 am »
Not exactly sure what you mean? they are either 94bore or 101.6 bore, 94 bore opened up to 101.6 would have the stud holes in the cylinder sealing area
This is what the chamber side looks like on my JPM head
« Reply #2 on: January 24, 2015, 09:19:21 am »
Just to be clear, that is a 101.6mm head
fastbus
« Reply #3 on: January 24, 2015, 11:06:00 am »
Hi Richie
Cheers for the pic. Your head chamber is showing more
metal against the barrel. Can this be a weak point to the head barrel sealing point?
« Reply #4 on: January 24, 2015, 12:43:25 pm »
Hi Richie
Shouldn't be, mine have been opened up slightly more since that pic so they fit all the common available cylinders, before we cut the cylinder to suit
spoolin70
« Reply #5 on: January 24, 2015, 15:27:53 pm »
Hi Paul
Mine have broken through slightly more than Richie's in his pic - the top couple of mm of the wall has gone and the rest is pretty thin. A good poke with a screwdriver and it would all break through completely. Sorry, no pics though, they aren't with me at the moment.
I did question this and it was pointed out that the cylinder seals on the top mating surface to the head so any area that does break through (on the side) is effectively covered over by the cylinder.
Hope that makes sense
Darren
fastbus
« Reply #6 on: January 24, 2015, 15:49:45 pm »
Cheers guys. Your answers are very much appreciated.
 Wink
neil68
« Reply #7 on: January 24, 2015, 22:04:31 pm »
I was recently looking at some 101.6 mm MS230 heads for sale.They appear to have broken through at the stud holes, but the cylinder sealing should be fine:
« Last Edit: January 24, 2015, 22:15:17 pm by neil68 » Logged
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
