October 13, 2026, 20:19:26 pm
| | |-+  Case Stud Torque
Author Topic: Case Stud Torque  (Read 6644 times)
Paul Bahnstormerz
« on: January 25, 2015, 23:13:28 pm »
Bolting the heads using Scat 8740 chromoly studs and Gene Berg case conversion kit with 8mm x 15mm wrench nuts. The studs didn't come with any notes on torque so going with the Berg advice  of 19-20lbs, is that enough? What torque would you recommend?
neil68
« Reply #1 on: January 26, 2015, 01:28:31 am »
I've been using the Scat 8 mm chromoly head studs for years in my 2332 cc with both CB 044 and JPM MS230 heads whiile sticking with the stock torque specification.  No issues in my street-strip Beetle Smiley
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
« Reply #2 on: January 26, 2015, 09:40:59 am »
23lbs
kielbasa
« Reply #3 on: January 26, 2015, 10:00:14 am »
I had berg 8mm studs and went up to 23ftlbs
dont you dare tell me turbo is better then N/A
Paul Bahnstormerz
« Reply #4 on: January 26, 2015, 12:31:29 pm »
23 it is thanks
« Reply #5 on: January 26, 2015, 20:10:24 pm »
you're not talking about 8mm studs at sealing surface of case are you?
Paul Bahnstormerz
« Reply #6 on: January 26, 2015, 23:44:45 pm »
No talking the head studs
« Reply #7 on: January 27, 2015, 00:13:09 am »
10-4
