September 24, 2026, 20:09:59 pm
| |-+  For sale!
| | |-+  Newly built 2332cc race motor with IDAs never run ***SOLD***
Author Topic: Newly built 2332cc race motor with IDAs never run ***SOLD***  (Read 6234 times)
Phil West
« on: February 07, 2015, 17:06:23 pm »
 I am selling this on behalf of a friend who unfortunately due to illness is having to sell his setup.
Details are:
Built by Tony at Microgiant
AS41 mag case
Mahle 94mm barrels
Wiseco pistons, notched
Early comp eliminators with the weld on VW rocker cover fittings. 41cc
FK91 cam
Lift measured at 658 thou
Pauter 1.5 ally rockers
Titanium retainers
44 x 37mm stainless valves.  Dual springs.  Single springs installed for running up.
30 thou deck.  Compression 13.5:1
Berg sump
Berg steel power pulley
The 009 is just in there to plug the hole so no other ignition with it
Early Italian IDAs
Scat ally pump cover.  Full flow oiling.
Jaycee pushrod tubes
Kennedy stage 2 clutch
Wedgemated crank.  12lb flywheel.
All parts brand new except the heads, carbs, flywheel and rockers
That's all the details I have at the moment.  More to follow if I get any.
Located in Essex.
Asking price £3,900.
Phil
« Last Edit: February 08, 2015, 18:15:51 pm by Phil West » Logged
Phil West
« Reply #1 on: February 08, 2015, 18:16:22 pm »
Now sold cheers
