November 02, 2026, 23:23:06 pm
| | |-+  What sized Cooler?
Author Topic: What sized Cooler?  (Read 5250 times)
UltraOrange67-2443
« on: February 23, 2015, 18:19:25 pm »
Hi all.
I'm collecting parts for a 2919cc T1 Motor.
It has a Autolinea block with no cooler in the fan housing.
I'm running the Scat fanhouse and wide cooling fan.
I have a Mocal sandwich plate thermostat and 2 Mocal 19 row 115mm coolers with Spal blow type fans, will they offer enough cooling?
I wanted to fit them on each side of the gearbox area, it is tight due to roll cage and torque bar setup.
Can anyone offer some advice?
Cheers, Nick
« Last Edit: February 24, 2015, 23:15:37 pm by UltraOrange67-2443 » Logged
1967 1200 2920cc EFI
« Reply #1 on: February 23, 2015, 18:33:51 pm »
Far too many variables. Only way to find out is to try it, ad more if needed.
spoolin70
« Reply #2 on: February 23, 2015, 18:42:31 pm »
I don't know the answer Nick but you might want to add :
1) CR
2) NA or turbo
3) Wet or dry sump
4) do you drive like a mentalist  Cheesy
Darren
UltraOrange67-2443
« Reply #3 on: February 23, 2015, 21:34:03 pm »
Engine spec.
90mm Scat flange Crank.
101.6mm JE custom Pistons.
6.0" pauter Rods.
JPM MS250 4" Heads.
JPM 408 Camshaft.
Pauter 1.5:1 roller Rockers.
Twin 48 IDA Throttle bodies.
Crank trigger ignition.
Omex 600 ECU.
Wet sump with 4 quart Berg sump with pickup mod.
Engine builder has talked about 12-13 comp area.
More street than drag.
Cheers, Nick
« Last Edit: February 24, 2015, 23:17:49 pm by UltraOrange67-2443 » Logged
