September 22, 2026, 21:02:01 pm
2388 cc Pro Stock Race Engine incl ignition - SOLD
Topic: 2388 cc Pro Stock Race Engine incl ignition - SOLD (Read 7035 times)
johandryselius
February 27, 2015, 08:41:04 am »
Hi!
The car and gearbox is sold - engine for sale - 10 passes only in total - all modifications and build by Johannes Persson - JPM "at its best"!!
ENGINE - 2388 cc Type 1 - 302,5 HP at 8400, torque 294 Nm at 6600 (there is probaly more in it since we had a little slip on the dyno):
Case: AutoLinea
Crankshaft: SCAT flanged billet 86 mm T4 all mains
Flywheel and clutch: SCAT with RLR Rev 6 clutch set-up - single disc
Rods: SCAT 5,7” H-beam
Rod bolts: Carrillo SPS, 12 point head
Cylinders: JPM
Pistons: 94 mm JE ultra low JPM
Camshaft & Gears: JPM Raptor custom grind 17,35 mm lift, flat tappet, Magnum gears
Lifters: JAYCEE tool steel
Cylinder head studs: Raceware Hi tensile 8 mm
Heads: JPM MS 250, CR 15,4:1
Rockers: JPM 5 point
Valves & Springs: Manley Titanium 48x38 mm, Oteva springs
Retainers: Titanium
Pushrods & Tubes: Manton double tapered, JPM tubes
Carbs: Gene Berg 58’s on welded angle flow manifolds, 50 mm venturi, Teflon coated by Tommy Tc Costello , JayCee linkage
Oiling: CB 4 Gear dry sump, special case modifications, JayCee bypass
Distributor: JAYCEE crank Trigger
Pick-up: JAYCEE crank trigger with with alternator combo
Exhaust: CSP Wasp 3
Ignition:
Ignition box: MSD 7 AL 3
Pro Power Coil
One new extra disc for the REV-6 included.
11000 euros or offer
Johan -
johandryselius@mac.com
Last Edit: March 16, 2015, 21:51:07 pm by johandryselius
1600cc Challenge Porsche 356:
9,4386@242,48km/h; 6,1229@193,15 km/h 1,50 60 foot @ Kjula Dragway 2022
1600cc Challenge Buggy:
9,5112@225,42 km/h; 6,0624@185,85 km/h 1,38 60 foot @ Kjula Dragway 2020
Europes quickest ProStock VW:
9,8538@218,80 km/h; 6,2569@176,24 km/h 1,35 60 foot @ BRC Tierp Arena 2014
Re: 2388 cc Pro Stock Race Engine incl ignition and racefuel
February 27, 2015, 21:16:45 pm »
That is cheap - good luck for the sell
www.Udobeckertuning.de
johandryselius
February 28, 2015, 12:57:41 pm »
Thanks Udo!
It is!
johandryselius
March 02, 2015, 20:05:40 pm »
Any offers!?
johandryselius
March 06, 2015, 10:32:19 am »
New price!
johandryselius
Re: 2388 cc Pro Stock Race Engine incl ignition - SOLD
March 16, 2015, 21:51:22 pm »
Sold!
