September 23, 2026, 06:05:43 am
| |-+  Wanted
| | |-+  94mm pistons 1.300 crown 1 or more damaged used etc. anything considered.
Author Topic: 94mm pistons 1.300 crown 1 or more damaged used etc. anything considered.  (Read 4866 times)
Phil West
« on: March 03, 2015, 17:18:57 pm »
Hi I'm after 1,2,3 or 4 of 1.300 crown height pistons to be used for mocking up to sort my required notches on a new set.
Everything considered!  Broken, damaged, missing pin, over notched, bodged, cracked.
Ideal would be an old 1 (or more) JE piston with huge notches.  But without notches would still be useful.
Phil
« Reply #1 on: March 03, 2015, 22:17:02 pm »
I have a set of strong JE with big notches . have to look for the comp. height
Can post pictures tomorrow
Phil West
« Reply #2 on: March 03, 2015, 22:31:55 pm »
 Smiley
« Reply #3 on: March 04, 2015, 13:11:22 pm »
comp.height is 35mm , come with 4 pin keeper per piston - like the Bergs recommened some years ago :-)
Phil West
« Reply #4 on: March 04, 2015, 13:31:04 pm »
Hi Udo,
Unfortunately I need a 33mm comp. height for setting up my motor but thanks for looking I appreciate it.  I've got a 35mm height old Wiseco set here and may have to mill off 2mm to get them right for mock up if I can't locate any of the 33mm.
Phil
« Reply #5 on: March 04, 2015, 15:31:23 pm »
No problem Phil .These can get cut off 2 mm too. And i have a set of new mahle cylinders for them - so if any body needs them call me
