October 13, 2026, 21:19:02 pm
| |-+  Wanted
| | |-+  Type 3 Backing Plates
Author Topic: Type 3 Backing Plates  (Read 6650 times)
RichardinNZ
« on: March 10, 2015, 20:19:31 pm »
Hello
I'm looking for some Type 3 rear brake backing plates....does anyone have any?
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
JIMP
« Reply #1 on: March 10, 2015, 21:41:23 pm »
Hello Richard
if you dont find any you could use front backing plates from a 1302/3. You need some lathe cutting to the center hole -to make it bigger- and drill the four holes for the bearing plate that holds it in place, then you make the rectangular holes for the handbrake cables and you weld a nut there for the fixing, and here you go you have your t3 backing plates. That assuming that you can do those jobs or have somene to do them for you, cheers
Friendly
Dimitrios
« Reply #2 on: March 11, 2015, 11:33:04 am »
4 lug or 5 lug?  I might have some still
RichardinNZ
« Reply #3 on: March 11, 2015, 20:20:35 pm »
Hi Richie
I 'll be using 5 stud drums; I heard the backing plates for all swing axle T3 will work though (although 4 stud ones have the extra adjusting holes in them)?
Richard
Dual Carb 36hp
RichardinNZ
« Reply #4 on: March 12, 2015, 19:39:40 pm »
Hi Richie
Did you get a chance to see whether you had these?  As mentioned in my post I am going 5 stud but understand that any type 3 swing axle backing plate will work?
Many thanks
Richard
Dual Carb 36hp
RichardinNZ
« Reply #5 on: March 15, 2015, 02:17:49 am »
Still looking for these and have a bit of a deadline!  The NZ VW Nationals are at Easter and keen to fit these in the next couple of weeks as I fit my new trans!
Dual Carb 36hp
« Reply #6 on: March 15, 2015, 08:08:07 am »
Had a look but cant find them, know I got some but where is evading me right now!!!
RichardinNZ
« Reply #7 on: March 15, 2015, 19:44:42 pm »
Thanks Richie.......if you do remember please let me know!
Dual Carb 36hp
RichardinNZ
« Reply #8 on: March 21, 2015, 22:41:34 pm »
Still looking! Thanks
Dual Carb 36hp
RichardinNZ
« Reply #9 on: March 26, 2015, 04:38:08 am »
Found some in Australia...Volksbahn, Sydney.  I think they may have more if anyone is looking.
Dual Carb 36hp
