September 23, 2026, 08:08:17 am
| |-+  For sale!
| | |-+  Flange crank bearings,type 4 mains
Author Topic: Flange crank bearings,type 4 mains  (Read 9050 times)
« on: March 14, 2015, 12:23:09 pm »
type 4 mains flange crank set , standard case and 0.25 mains, this is an older bearing set, new in package from 1999 when quality type 4 bearings were available
Ģ150
« Last Edit: January 28, 2016, 10:02:35 am by richie » Logged
« Reply #1 on: January 28, 2016, 10:02:58 am »
Still got these  Smiley
Silversoar
« Reply #2 on: January 28, 2016, 10:25:39 am »
PM!
hope its the right type!
« Reply #3 on: January 28, 2016, 16:29:01 pm »
PM!
PM sent Smiley
« Reply #4 on: February 02, 2016, 11:28:35 am »
Sold  Smiley
« Last Edit: February 02, 2016, 14:46:44 pm by richie » Logged
Jukkis Maki
« Reply #5 on: February 02, 2016, 16:10:35 pm »
Any 0,5 mm/0,25mm (case/crank) Typ 4 bearings for flange axle in stock?
Jukka
« Reply #6 on: February 02, 2016, 17:11:37 pm »
Jukka
Hi Jukka
no this as only set I have
dangerous
« Reply #7 on: February 02, 2016, 22:18:04 pm »
Jukka
You will need a couple of these, and make your own:
http://www.ebay.com/itm/New-Mahle-Main-Bearing-Set-010-Crank-020-Case-021198493A-/291656199104
« Last Edit: February 02, 2016, 22:21:51 pm by dangerous » Logged
1946vw
« Reply #8 on: February 02, 2016, 22:22:20 pm »
I made many of them, just take your time.
« Reply #9 on: February 03, 2016, 09:32:01 am »
Jukka
Dave have you tried those ones? I have kept away from them as thought they have the soft all aluminium center bearing?  cheers Richie
dangerous
« Reply #10 on: February 03, 2016, 11:12:09 am »
No, that was just one that came up with a google search of the 021 198 493A part number.
Bummer if they are all aluminium.
For VW case-type flange bearings
I normally use 3 sets of split centres (bmw, type 4, or type 1 depending on crank)
and a To#Īta thrust washer set at the FW end.
I have not had to deal with a 0.5 tunnel yet.
dangerous
« Reply #11 on: February 03, 2016, 11:33:30 am »
http://www.ebay.com/itm/VW-Silver-Line-Main-Bearings-Steel-Backed-020-Case-010-Crank-Type-1-/221965521563?hash=item33ae2d129b:g:lRAAAOSwp5JWZ39J
« Reply #12 on: February 03, 2016, 11:56:40 am »
Thanks, we use the silverline all the time but I just wondered if the mahles where an option, will stick to what works for now then Wink
Jukkis Maki
« Reply #13 on: February 03, 2016, 21:07:34 pm »
Thanks, but no thanks for this kind of "I made by myself" - stuff. Scat found one set of their storage, so it should be last one existing in the world just now  Grin
Jukka
« Last Edit: February 04, 2016, 16:26:12 pm by Jukkis Maki » Logged
1946vw
« Reply #14 on: February 04, 2016, 21:57:48 pm »
Where does Scat get them?
