September 23, 2026, 09:19:49 am
AS41 Performance Case
Topic: AS41 Performance Case (Read 2456 times)
March 15, 2015, 12:04:05 pm »
Dual relief AS41 Engine case for sale.
AE code. Has been line bored 40 thou. Standard thrust. Case has case savers also.
Stroker crank clearenced. Modified for full flow and cut for sand seal. Bored for 94mm Pistons also.
Have the silver line bearings that were fitted and they are a great fit.
The only down side are the lifter bores have ovaled due to a high lift cam being used. Need re-bushing. To be honest mag cases need this even when new if using a high lift cam as the inserts are a harder material to prevent this.
If you have access to a machine shop its am easy fix
Will deliver case to Volksworld.
£150
