October 06, 2026, 06:10:43 am
352314 Posts in 28957 Topics by 6926 Members
Latest Member: Chakalives
| | |-+  Tachs and Magnetos
Author Topic: Tachs and Magnetos  (Read 10237 times)
RobtheManx
« on: March 21, 2015, 21:19:34 pm »
Hi everyone , I'm planning to run my 2180 in my street car , the motor uses a Mag .
Was wondering if anyone on here has had experience with Magneto Tachs . I have one of the Joe Hunt signal convertor boxes to wire the Tach when I used the engine in Ned Bug , but I never did get it to work , despite following the wiring diagram .
Has anyone used an old Sun Tach which run off a sender unit ?
Also wondering if there is any kind of magnetic pickup which can be run off the pulley to feed the tach ?
Thanks , Rob
vwhelmot
« Reply #1 on: March 21, 2015, 22:23:07 pm »
I'm going to run a mag too and already have the hunt converter box but I have a nos 80mm speedwell tach. Me thinks I might have a few issues with my set up and I'm prepared to finish the car without a tach altogether.
RobtheManx
« Reply #2 on: March 21, 2015, 22:49:37 pm »
Yeah I've got a feeling I'll end up not running a tach too .
vwhelmot
« Reply #3 on: March 21, 2015, 22:51:19 pm »
I think I will be keeping it simple, no additional gauges whatsoever. They are so last decade anyway! Lol
Pas
« Reply #4 on: March 21, 2015, 23:19:05 pm »
I don't know about the Sun tach but I know Auto meter made a mag specific tach, model# 5620. It is discontinued now I believe, so I have been looking for a NOS or used one for a while now with no luck so far. If you hear of one for sale and don't want it yourself give me a shout  Wink
I have a NOS Porsche 912 tach fitted at the moment and will try and get it working with a Joe Hunt converter box, but I'm not holding out much hope as I have been told by several people they are tricky to get working at all and if they do work may not give an accurate reading!
Rocket Ron
It's old school for a reason
« Reply #5 on: March 22, 2015, 10:07:34 am »
Hi Rob
I ran a auto meter signal conversion box and an autometer pro control with it and this seemed to work quite well and did give a steady tach.
Also tried the two step that the guy in America makes but with mixed results.
Magneto tachs do come up quite a lot on evil Bay and are usually cheap to as there is not much call for them.
Regards Ron
13.12 @ 101.84
Grooving out on life
jick
« Reply #6 on: March 22, 2015, 10:46:20 am »
Hi Rob
Hey Rob...... I have the same set up as Ron in my 59,
It'll come as no news when I say it's untested/Un-run as yet, but I had the wiring done by a couple of fantastic chaps who were well used to all the various Autometer/ Magneto components etc etc  they only do vintage /rally /race type stuff from the early 1900's through to 1970's Formula 1 cars...they loved doing my VW, said it made an an interesting change from Pre-war Lagondas!
They're based in Tenbury Wells..... Shoot me a PM and I'll pass on their details if it helps..
Jick.
RobtheManx
« Reply #7 on: March 22, 2015, 11:28:16 am »
I actually have an old Autometer Magneto Tach in my stash , but wasn't sure if it will suit my car . Wanted to use an old Stewart Warner greenline . If I don't use the Auto meter I will sell it to you Pas .
RobtheManx
« Reply #8 on: March 22, 2015, 11:29:53 am »
So no oil pressure or temp either ? I was thinking about hiding them in the glove box , save cutting the dash .
« Reply #9 on: March 22, 2015, 18:11:45 pm »
you don't need that either,  that way you have all the space to put a boost gage later on with the next engine  Grin
vwhelmot
« Reply #10 on: March 22, 2015, 19:43:07 pm »
It used to have oil temp and pressure but to be honest, they are not going back in. I trust my engine builder. Smiley
Pas
« Reply #11 on: March 22, 2015, 22:01:53 pm »
[/quote]
[/quote]
Thanks Rob.
« Reply #12 on: March 23, 2015, 02:21:30 am »
I am pretty sure I started a thread similar to this a while back..... I am sure some one will find it and post a link  Undecided Smiley
I have since spoken with Ian @ WPS and he is working on a PROPER electronic convertor for mags, I haven't heard from him in a while so maybe he has some developments....
You could always go for a "Mechanical Drive" unit...
« Reply #13 on: March 23, 2015, 12:49:11 pm »
I've never used a magneto, so I had to do a bit of "G@@gling" to find out what the problems may have been.
After reading this.......
http://www.donzig.com/tachometers.html
........I thought, "Yep, OK".
I'm an electronics tech, so apart from using a readily available kit for a sine-wave-to-pulse converter to drive a standard modern tacho, I thought an easier and simpler way would be to just use a tacho designed for a diesel, which are run off the vehicles alternator.
https://www.google.com.au/search?q=alternator+tach&biw=1920&bih=910&tbm=isch&tbo=u&source=univ&sa=X&ei=afwPVfWyJqW1mAWaxIHYBg&ved=0CGkQsAQ
I rekn one of them will do the job. Hope it helps.
« Reply #14 on: March 23, 2015, 12:57:12 pm »
Hmm interesting....
WPS
« Reply #15 on: March 24, 2015, 23:57:53 pm »
There's a few options here....
I've been working with a company to modify any tach you like to work with magnetos with mixed results but I think we're getting there now.....I hope to be able to offer this service once we have an accurate/reliable set up.
The converters suffer from EMF interference from the mag so sheilding the wire can help but usually they're twitchy and annoying!
Rob: I have a SW greenline tach with the appropriate Sun tach converter (very rare in 4cyl mag spec) which I'm gonna be wiring up in my '52 once I have the motor finished/started  Roll Eyes so I'll let you know how it goes.
I also run a cable drive Jones tach from my Mallory mag in the Fiat....that works great and is period correct but again hard to find....and I rarely have time to look at it anyway but it's nice to have......reminds me of the start sequence in 'LeMans'  Grin
Wolfsburg Performance Services
   WolfsburgPerformance.co.uk
      Instagram:  wpsengines
             07880-311850.
RobtheManx
« Reply #16 on: March 25, 2015, 09:32:20 am »
Hi Ian, thanks for that will be interesting to see how it goes with the Sun convertor . I'll run some extra wires through the car and leave it at that for now .
I believe the Lancaster Pilot and I will be coming to see you in April finally with his engine .
Cheers , Rob
