September 22, 2026, 01:30:13 am
New Vallero trans build for Hugo, 1963 bug w/ 2185cc
Topic: New Vallero trans build for Hugo, 1963 bug w/ 2185cc (Read 30563 times)
dsimas
March 27, 2015, 21:39:40 pm »
Hello everyone. Long time, no build thread! I've been busy, I got married! Oh and I've been training a wild mustang and driving a big rig over Donner Summit 3x a week. Yeah, lots going on and it's time that Hugo get a much needed upgrade. Many of you are familiar with my Daily Driver and the 2185cc engine that Ray Vallero and I did a build thread on a few years ago. It's been fun, especially at the track. But the limiting factor to seeing what it's really capable of has been the old tranny. It's 15+ years old, with countless miles as a commuter.
Let me preface this thread by saying that this is not a manual on how to do things. I am not a mechanic. I have a great teacher and friend in Ray Vallero, and I am simply playing photo-journalist.
I know that my video resolution sucks, but that's my phone and I'm not buying a new one just for this. Also, the choices that we are making for this build are exclusively made for my unique use. This car is a driver, but also capable of the 13's at the track, so I want something streetable and able to take a beating.
We will be building this transmission complete outside the car. The entire center section; with axles, tubes and rear wheel bearings. Then we will swap it out into the car. Let's start with what I have. It's a 4.12 r/p with a close ratio 3rd gear. At the track, it sucked at the top end. Over-revving 3rd or lugging 4th, and I couldn't make the stripe in 3rd with any benefit to my ET. But this combination has suited me for 37 years with this car, great for around town, but 4th was high enough for the highway.
The current trans has taken some abuse. At the track, I've tried to always allow my ET to suffer in exchange for leaving the light cautiously, in exchange for being able to drive my car home and to work the next day. However, a few months ago wile simply driving in town, we suspect it has lost a tooth or two in the small spider gears. It was probably cracked and finally went. So, it's time.
Ray's daughter Lynda build a cutaway trans as a highschool project and he is using it here for demonstration:
http://www.youtube.com/v/AYgDR0JxXxE
We need to remove the stock ring gear carrier from this cutaway model so that Ray can show some basics to start this thread. I'm a girl, I like details for dummies. You are generally all guys out there, you are visual. I'm trying to satisfy us all.
Ray has a VW Factory tool kit given to him when he was racing the Bug Iron in the 1960's. Tool #VW297. Way cool.
And using it:
http://www.youtube.com/v/nKto89cPCGY
Now that it's removed, he explains how things work.
http://www.youtube.com/v/ueTCCKJxd9k
I'll be using a super diff housing in order to use four spider gears instead of two. This will probably initially be controversial with you all saying it will be dry and never last. We will be modifying it to solve that.
http://www.youtube.com/v/m466X8EvAYo
This is what I have now:
And what we will be going to:
That's it for now. Next up, we'll start modifying some parts...
Last Edit: March 31, 2015, 20:43:02 pm by dsimas
Re: New Vallero trans build for Hugo, 1963 bug w/ 2185cc
March 27, 2015, 23:50:44 pm »
Dawn, I followed the engine build thread with great interest, and was quite sad when it ended! I know very little of the fine details inside a trans, so I'm really looking forward to this!
56BLITZ
March 28, 2015, 08:14:18 am »
I'll be watching also!
Pedalpusher
March 28, 2015, 09:18:18 am »
Your threads are top notch! So meticulously explained everything, so nice to follow!
-Mikko-
dsimas
March 28, 2015, 20:18:13 pm »
Thanks for the compliments everyone! I'm glad that you enjoy these, and hopefully can learn something like I do.
Okay, so we sent the carrier, all the gear sets, axles, and some bearings to be cryogenically processed. This procedure is becoming popular and makes the metal stronger and more able to dissipate heat. The way it was described to me is that they slowly bring it down to -350F and then hold it there for 12-24 hours. Apparently this makes the atoms the same distance from one another to become a stronger structured alloy. I'm not sure if this descibes it accurately, but I have cattle and they do it with sperm and it works. That's the extent of my first hand knowledge, lol.
We wanted to test this out. So, we also sent in a sacrificial 2nd gear. But before it went, we broke a tooth off and filmed it. We locked it into the vice the same way before and after.
Before, this is very easy. One tap.
http://www.youtube.com/v/69wZbf6QTEk
Then, after cryo:
http://www.youtube.com/v/4bh95D-y1-A
That's success, definitely harder to break afterwards. Awesome sauce. 8-)
We'll be using the latest case that came with two side covers.
This passenger side cover is brand new:
The other side will be billet aluminum so it's stronger for the pressure applied by the ring gear.
The first modification will be to these side covers. The bearing is spinning so fast that it is normally difficult for oil to get in from behind. Ray will mill out an area on each one to allow oil to run over the top of the bearing and get behind it. It'll be a little dribble constantly while driving, behind the bearing on the outside of the diff housing. This will oil the fulcrum plates and the side gear. Here he explains this:
http://www.youtube.com/v/FnBADj2eiPI
As he gets ready to do this, he needs to set up the Bridgeport mill. First, his "big ass vice"... (and it's not smoking, lol)
http://www.youtube.com/v/D7PEMC04Qsg
Just a segment of the 10+ minutes it took to setup for a few seconds of milling.
http://www.youtube.com/v/BZ2Q3KL5nmY
And finally, here he is milling the passenger side plate.
http://www.youtube.com/v/iLrH5V5B8g4
The milled out area is at the top so that oil spills down over the bearing. You can tell the top by the stud holes being further apart.
Now the aluminum one.
The hole is milled past the shelf that the bearing sits on to allow oil to go through to the back side of it.
Next up, we will be modifying the ring gear carrier. Very interesting stuff!
56BLITZ
March 28, 2015, 22:36:03 pm »
COOL!!!
Thanks Dawn!
dsimas
March 29, 2015, 18:42:00 pm »
Today we are going to modify the ring gear carrier housing. It's a super diff and that will probably make some people cringe because of the lack of oiling, lol. But Ray says his mods can make it work and is excited to show you all how.
As a reminder from day one, here's a super diff on the left and a stock carrier on the right.
Here Ray shows where the spider and side gear are in relation to the oil hole on a super diff (inadequate).
http://www.youtube.com/v/5ZhN6AgJHW8
We will be enlarging the current two oil holes to 1". There is one on each side. Note the hole is in front of the paddle, which pushes the oil into it as it rotates. By the way, a bus trans' carrier goes other way, so the hole would be on the other side of this paddle.
Here Ray explains the larger hole that we will create:
http://www.youtube.com/v/kjqZtcnuSvs
And here he explains how these two new oil holes will not damage the integrity of the housing. As he says at the end of this video, consider how large the holes are on a stock housing.
www.youtube.com/watch?v=tLDPyEDkfMM
Milling the 1" oil hole. This hole is not perpendicular, it is actually angled as a scoop. You can see this by the angle of the housing to the bit entering it.
www.youtube.com/watch?v=K9YfdjSq7ng
First draft of the hole:
Next, for even better flow, he will mill a "ramp" into the new hole. Like on the hood of performance cars, rather than sticking up, it's recessed to help ease the flow in.
Milling the "ramp":
www.youtube.com/watch?v=EPiDoyX1jH8
Done.
Here Ray has assembled the side and spider gears inside the housing after milling it on one side. He is comparing the difference in exposure of the gears through the manufacturer's hole and the larger one.
www.youtube.com/watch?v=PHYGqcMx1qA
Next up, the holes in the carrier housing for the side gear are tiny. He will now be enlarging two of them to 5/8", opposite the large oil holes that he just milled. This will make provisions for the side gear. Again, he will put a swath in it so that it's a pumper.
In this picture, you can see both the 5/8" hole Ray just milled and manufacturer's smaller hole. They are both in the darker narrow recessed ring on the housing.
This picture is on the other side. It shows both the new larger oil hole and the larger ring gear hole.
Ray notices that the super diff is softer material than stock to grind. That's why it needs lubrication! Ray thinks that stock is cast steel, the super diff is a cast iron alloy. All this work causes friction and makes it magnetic. And probably causes global warming...
Lot's of milling today! Ray says, "Sometimes I wish all these parts were made out of wood, it'd be a lot easier." Yeah, but then it wouldn't be so:
But wait, there's more! He is also putting four new 5/16" holes in the thickest, widest part of the housing for oil to circulate out. Otherwise, it's a real sediment maker. Another interesting point: the longer the hole, the more draft it creates; so it actually pulls the liquid out. If anyone has a woodstove, it's the same. The longer the stove pipe, the better it pulls. These holes will be long and deep. These will also be showering the pinion head and pinion bearing, which will also be totally oiled. Ray explains these exit holes.
www.youtube.com/watch?v=nEtk0ZKa6VQ
Here it is getting milled. You can see the ramped swath on the new 5/8" ring gear hole behind the bit.
Here is the end result. A super diff housing that will not run dry! Afterwards, in true Ray Vallero fashion, he grins as he sees all the shavings after today's work, "And now it'll be lighter too." Heh, heh.
www.youtube.com/watch?v=iFdVDRmpwdM
dsimas
April 01, 2015, 06:37:16 am »
Question: Can you guys all see the videos embedded in the last post about the carrier housing? I show the first few embedded and the remaining ones only as a link. Maybe it's just my slow browser...
Also, FYI for those who want to see it, here is my engine:
Jesse Wens
April 01, 2015, 16:47:51 pm »
very nice documentation of the job at hand you are writing down. Thanks a lot
I also see the movies as links but the movies work for me.
Jesse
dsimas
April 15, 2015, 09:01:43 am »
Boy, do I have news today! I don't know how many of you have Hagerty Insurance (Classic Car Insur), but we have always used them. My husband and I were nominated by a call center agent for Classic of the Year with Hagerty when I called to combine our policies and change my name. We met through VW's, got married in our VW's, honeymooned in our VW's with other VW's... Well, you get the picture. We won. Classic of the Year for 2014.
They are flying out a media team to do a story on us. It will be on their website and magazine, etc. So, time for Hugo to get a new paint job in a big fat hurry.
Ray pulled the engine and trans today and put in a 3rd wheel so it will roll and we are towing it to the body guy in the morning.
If anyone in the Sacramento area wants to see the big reveal and be interviewed by Hagerty's film crew (or just meet with them while they are here from Michigan), here's a Facebook event for a meetup on June 6 in Auburn at Mel's Diner. Join us, and then cruise with us to the Straight Up Dubs VW Show in Elk Grove afterwards.
https://www.facebook.com/events/1579290465659825/
Back to the transmission... Look what was stuck to the magnetic plug in my old tranny. Three guesses?
Yep, *three* spider teeth. Just as Ray suspected.
Also, here's an opportunity to show you all the traction brace that Ray made last year. "Rabbit ears" that brace the trans to the firewall. I can't use a typical traction bar because when I "Cal Looked" the car back in 1978, the fenders were welded to the aprons in front and back. The beading was removed from the body at that seam for a smooth look for shows. It would crack there if I braced the trans to the body. So, here's what I have:
And, yes, that is original paint! I have never painted the interior dash, trunk or engine compartment. I've only painted the exterior. This time we will paint the engine area. Going to be amazing. I will sort of miss that burnt section on the right where my old 40 Weber aircleaner caught on fire in 1992 at Sears Point Raceway... :/
And one last thing for today. Here's a video of Ray explaining in layman's terms why a VW transaxle is so efficient. This is Basic 101 for most of you, but I will put it up anyway. There are only a few inches between the engine and the transmission in a VW and that results in more horsepower getting to the wheels. And that's a win-win. Either, it's a 90# weakling and we need every bit of HP transferred to the wheels to get up a hill... or it's a raped ape blowing the doors off a muscle car.
www.youtube.com/watch?v=GlAojToX6ZU
In my next update, I will show you one last modification that the ring gear carrier needed to clear my larger pinion head. Stay tuned!
dsimas
April 17, 2015, 23:39:28 pm »
Yesterday I had Hugo hauled from Vallero's VW Werks over to Jim Arbogast's, who will be painting the car while we finish the tranny. This is how you do it with only two front tires. Ray has this third wheel that makes it very stable and easy to move around.
www.youtube.com/watch?v=rc1F4Qbb9_I
By the way, I got a question on a youtube video asking where I bought the ring gear carrier. Mine is a Weddle, but they don't manufacture them there. Ray says he's bought them from three different places and they are all the same. I don't know where they are actually made.
Here's a little machining that we did last week. One more thing had to be done to the ring gear carrier. My pinion head is larger than normal, so he had to reduce the diameter of the housing to clear it.
Mine is a Gleason, it's on the left at 36mm. A stock pinion is on the right, it is 31.20mm.
Here it is with the matching ring gear.
Something interesting: When manufactured, a ring gear is lapped in on a Gleason machine, bolted into it like in the car. They move the pinion in and out and where it is the quietest, they write that number down. That number is stamped onto it and used to set the pinion depth.
We need to reduce the diameter of the housing to clear the pinion head at the point where it is touching in this picture.
On to the metal lathe. This machine is huge and is as old as Ray, they were born the same year. :shock:
At 1:14 in this video you can see the hole for the roll pin flashing in the lathe at the top edge of the carrier. He's watching that to know when to stop.
www.youtube.com/watch?v=tDcLnrQz1RA
Now it is about .040 smaller than factory. The material may look thin where that roll pin goes through, but Ray says that it will be fine.
This is the small spider gear cross shaft and split roll pin. The slot in the roll pin will face the outside of the carrier housing, open end up, to only allow the solid part to press on the material. That way the open side isn't putting any pressure on the weakest spot. The pin will be holding it in also, so it will be supported adequately. (He will be grinding the cross shaft down shorter, but hasn't done that yet)
dsimas
May 03, 2015, 21:42:37 pm »
First, I want to address two questions that I received from another forum....
Quote from: andy198712
How do those ears mount to the gearbox?
Sorry for the confusion! After I posted those, I realized that I hadn't mentioned that this photo is simply a mock up to show them. They actually do not mount directly to the housing this way:
As you can see, they mount to the two upper studs. But they actually mount on the studs after the engine is in
between
the fan housing and the nut. There's no way to get a photo of that though. Does that make sense?
Quote from: esde
When you decided to do the "ears" for the frame horn brace, did you consider using a "kafer" style frame brace? As it mounts to the shock mount, I doubt it could stress the body any more than driving a rough road.
In case people reading don't know about a Kafer Bar, here's an example:
http://www.kustom1warehouse.net/Bolt_on_rear_truss_bar_for_VW_Volkswagen_p/6518-11.htm
Kafer bars are a good improvement to using a rear engine bar, but not as good as the rabbit ears. Ray has done the rabbit ears for decades and they are a relatively simple design with the best result. I took some new pics to elaborate a bit more about this subject since wheel hop is serious. First, consider the fact that the frame horns stick out quite a ways and are unsupported.
Common ways to brace the transmission are by a rear trans mount, a mid mount, nose mount, and often a rear engine bar on the body (which often just *squeezes* the engine/exhaust). Here's a case showing all three mounts (on top of picture, which is the underside of the trans).
Here it is in the car. The case, and the engine, is suspended out on the horns (which are long) and is secured only on the bottom. Even if you weld a brace or horns to a roll cage, or use the kafer bar to the shock mounts, you may stop the up and down motion of a wheel hop, but the transmission case still is able to
rotate
Twisting the case can misalign the gearsets. With the rabbit ears, the case is secured from the top and on the rear end of the frame horns. We are addressing the twisting, not just up and down motion. And they leave the bottom of the car with a lot of room for coolers and access to everything.
As for today, we will be assembling the gear set on the pinion shaft. First, Ray will be handpacking the needle bearing, instead of using a stock needle bearing cage. This doubles the load capacity. Here is a photo of a pinion shaft, pinion bearing, and a stock 1st needle bearing (not mine).
Here Ray explains what we will be doing:
https://www.youtube.com/watch?v=Cz1XRpKlUxo
In the 1970's, Ray would take two of these cages and break them apart and pull all the needles out. Then he would hand pack them onto the inner race with grease. Gene Berg loved the idea and finally started selling the needles for handpacking. This is from Gene Berg's Tech Manual & Parts Catalog:
Here's the ones that we bought, sold loose for handpacking. Something that Ray developed! There are 43 needles in each bag. A stock cage has probably half as many. We are using them for 1st and 2nd gear.
And this is the tedious (and messy) work to do it. It's not so bad if you use a lot of grease. We are doing it here only for demonstration. As you will see later, we have to take this apart in order to install the nut and preload the pinion bearing.
www.youtube.com/watch?v=23JfP8Teoxo
After packing, we have almost 100% surface contact.
Here Ray explains the late model pinion bearing that we will be using. It has the thrust washer built in for a more rigid bearing with a stronger thrust surface.
www.youtube.com/watch?v=mwPSu5FMqlA
Next up we will press the pinion bearing onto the shaft. Then preload it.
Two halves make it to where the bearing preload can be adjusted by torquing them. This can only be accomplished by a seasoned technician. If you try this on your own, you may destroy the bearing. Sometimes the new bearing preload is lighter than Ray would like.
Pressing the pinion bearing onto the shaft.
Next the inner race is put on the shaft with loctite. Followed by the small round nut. Then he will put this into a vice and torque the nut to create a small amount of preload.
www.youtube.com/watch?v=PvRkh1zugts
Preload is the inch pounds of torque required to turn it. It requires a torque wrench similar to the one here. We'll go into this more when we put the pinion into the case.
www.youtube.com/watch?v=LiRAvJo-Qyw
Why do you preload a bearing? Because any bearing is subject to a lot of load. We prefer to have zero clearance, so the bearing can't ramp up and change the parts location by movement. By preloading, we are ensuring that the pinion head is going to stay where it starts off. Mine will be light on preload because it's a driver. That may lighten as it breaks in, but then it will not have any clearance. If we didn't preload it now; as it breaks in, we may not have zero clearance later.
Last Edit: May 07, 2015, 16:50:54 pm by dsimas
dsimas
May 13, 2015, 19:14:19 pm »
Just a quick note that Hugo's paint is coming along. It's being done by Jim Arbogast in Auburn. He's retired and takes on a job as time allows. He prefers to do classics. He's been doing VW's for over 40 years. In the 1970's he had a contract with a VW dealership when everyone was trading in their '60's VW's for the new '70's models. They would send the trade-ins to him for fresh paint. VW's were so popular then that he was doing one every day!
He's taking Hugo down to bare metal.
The car has never been "restored" since I've owned it for most of its life. But needed some body work here and there. Like where all the chrome removal welds were, and also where it was dented on the front of the hood.
I bought this decklid in 1979 at BOR's swap meet because Hugo's wasn't correct for the year. Turns out it was not straight at all.
Painted the engine compartment for the first time. We had taken the felt off the firewall for the rabbit ears last year and the OG paint was covered in glue.
All reassembled and getting a tow back to Ray's shop.
Jeff68
May 14, 2015, 14:08:46 pm »
Thanks for posting the progress of Hugo.....I'm learning so much by you narrating the work and modifications that Ray is doing and has done on your cars's engine and transaxle. Even though I don't think I could build a transaxle I now know more about what to ask someone if I paid them to do it (unless I had Ray build one for me!)
Did the bodyman / painter do the work at his home? It looks like he painted your car in his driveway. If so it still looks great and it seems he did it relatively quickly. I'm glad all the work is going well on your car.
dsimas
May 14, 2015, 19:20:03 pm »
Quote from: Jeff68 on May 14, 2015, 14:08:46 pm
I'm glad that it's helping you have a better understanding to what goes on inside a tranny. It not only can help us if we have one built, but it can help us visualize what is going on when we drive them so that we can make them last longer. Education is always good.
Yes, Jim painted it in his garage. He had a shop in town for decades and recently retired. He did it very quickly, probably 5 weeks. Considering it was a complete disassembly, that's where his VW bug experience came in very handy.
dsimas
June 12, 2015, 03:10:44 am »
In the last segment, we pressed on the large pinion bearing and small round nut and added preload. Now we put the needles back on and slide 1st gear over them, and add the 1st gear syncro ring. We added one shim to bring the clearance between 1st gear and 1st gear hub to within Ray's specifications.
www.youtube.com/watch?v=SOEyCDk8H7k
The locking ring on the small round nut is torqued and staked. The staking is so that it cannot rotate when it's in place in the transmission, unless done with a wrench or tool. We put Locktite on it also.
Before:
During. He uses a flathead screwdriver on the edge and taps it with a hammer.
After. See the small dent?
Now for the dogs and clips:
Here Ray is adding the dogs onto the 1st and 2nd operating sleeve and hub.
www.youtube.com/watch?v=H1-m58srzEc
Then the 1st/2nd operating sleeve and hub with the dogs in place go on the shaft.
And now with 2nd gear syncro.
3rd and 4th idler gears go onto the main shaft.
Now with gear carrier housing set on them.
Here are the main shaft ball bearing (large one) and small pinion needle bearing (4th gear end). Manufactured by Fag. To install these we will heat the housing to 160 degrees and then drop the mainshaft bearing in place and slide the pinion needle bearing in place, watching for alignment with the retaining bolt into a recession in that bearing. The retaining bolt goes into the hole on the side of the housing, directly below the small bearing in the photo.
This is just a mock up of where things will go. Here you can see the recession in the small needle bearing for the retaining bolt (but not lined up properly in the photo).
dsimas
July 04, 2015, 19:31:04 pm »
Hi everyone. I have some very sad news. Ray had a massive heart attack yesterday at the shop. He was resuscitated twice and has not regained consciousness. They have put in into a hypothermic state to help increase his odds of survival/brain damage/organ failure. At this point, I am asking for prayers and believe in the power of prayer. I will update the forum with any developments.
Thank you for your support.
KRS808
July 04, 2015, 23:27:04 pm »
Very sad news indeed. The most positive of thoughts and prayers going out to Mr Vallero and family.
Aloha, Christian Saunders.
July 05, 2015, 09:09:26 am »
sad news indeed. it doesn't sound good, but i hope for the best.
July 05, 2015, 15:19:07 pm »
Sad news
Ray looks to be a very good guy , full of knowledges and prompt to share it.
Good guy desserve good thought
Jeff68
July 06, 2015, 14:44:34 pm »
Oh no.......I hope he recovers. Prayers for Ray and all of his family and friends in this tough time.
dsimas
July 10, 2015, 22:04:38 pm »
I am very sorry to announce that Ray Vallero passed away last Tuesday. He had a massive heart attack at work and never recovered. As you can imagine, we are all very saddened and shocked. I will be attempting to finish this build thread with the help of his daughter Lynda.
I am helping the family at this difficult time, so please be patient as they decide the future of the shop. We will be putting together a memorial event. It will probably include a car show and caravan. Possibly from Southern CA up to Northern CA, with the memorial here in Auburn.
He will be greatly missed. I am forever grateful to have had the opportunity to document as much of his talent as we did, and also to have considered him one of my oldest friends.
Dawn
July 11, 2015, 11:32:19 am »
Dawn, I'm so sorry to hear this. I've been checking in on this thread for any news and feared the worst. I don't do prayers but I'm thinking of you and Ray's family and friends. It's little consolation but at least he was in a place he enjoyed doing a job he loved.
Neil
July 15, 2015, 19:30:40 pm »
sad to hear and yes he will be missed. i really enjoyed how he was keen on sharing what he does and sharing his experience.
July 17, 2015, 21:48:08 pm »
My condolences, as has been said Ray died doing what he loved and he will be missed.
bedjo78
July 17, 2015, 22:38:03 pm »
Sorry to hear the lost of vw pioner. His share of knowledge will never die
NoBars
July 22, 2015, 23:11:52 pm »
On a lighter note, as a Hagerty customer I believe congratulations are in order.
https://www.hagerty.com/articles-videos/Articles/2015/07/20/VW-love-story?utm_source=ExactTarget&utm_medium=email&utm_term=&utm_content=&utm_campaign=Hagerty%20Weekly%20News%207-22-2015
dsimas
July 22, 2015, 23:23:47 pm »
Quote from: NoBars on July 22, 2015, 23:11:52 pm
Thank you NoBars! Hagerty Classic Car Insurance was out to CA to film us for this story and got hours of video of Ray Vallero just a few weeks before he passed. We are so grateful to have that footage. I also have some help in finishing up this build thread, so stay tuned...
Here's the story/video done by Hagerty Insurance, awarding my husband Tom and I "Classic of the Year 2015".
Full article along with the video here:
And here is the story about Ray Vallero that was added after he passed away:
https://www.hagerty.com/articles-videos/Articles/2015/07/17/Ray-Vallero
Here's just the video for those of you that don't like to read the extra stuff...
www.youtube.com/watch?v=DIr-hHL_yzM
Dave Rosique
nobodyouno
July 23, 2015, 05:38:13 am »
Hi Dawn,
I've never really chimed in much but have always enjoyed your posts! My Wife & I just watched the Hagerty video (we are Hagerty customers as well). Congratulations! The video was awesome and us die-hard VW owners truly "get it"
We love your story! You and your Husband were awesome!
I must say it brought a tear to my eye to see Ray.. I never knew or met him but I have known of him for many years.
The tribute to Ray in the end was very touching. I guess that's all for now..
Take care,
Dave Rosique
andy198712
Reply #29 on:
July 23, 2015, 13:30:12 pm »
Quote from: Dave Rosique on July 23, 2015, 05:38:13 am
Hi Dawn,
Take care,
Dave Rosique
My thoughts exactly! Very touching, beautiful wedding also
