September 23, 2026, 18:06:06 pm
| | |-+  Clutch Pressure Plate
Author Topic: Clutch Pressure Plate  (Read 4544 times)
RichardinNZ
« on: March 29, 2015, 08:47:56 am »
Now that my new transmission is fitted and I'm about to reinstall the engine I realise that the release bearing that self destructed has damaged the ring on the pressure plate that it should sit against. Is this an issue or should I pull it apart and clean it up?
Many thanks
Regards
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
Martin S.
« Reply #1 on: March 31, 2015, 00:11:36 am »
Slap it back in, good for another 40 years haha  Roll Eyes
dragvw2180
« Reply #2 on: March 31, 2015, 01:16:27 am »
JMHO   If that damage is as bad as it looks I would change the washer , an easy job . Mike McCarthy
RichardinNZ
« Reply #3 on: March 31, 2015, 05:26:22 am »
Thanks...taken it off and will see whether it can be machined (or whether it will get too thin).
Richard
Dual Carb 36hp
dragvw2180
« Reply #4 on: March 31, 2015, 14:32:14 pm »
I am sure someone on here has one they removed when they went from late model to early model clutches. I know I have one in my tool box but shipping would be stupid from North Carolina , USA to you.
RichardinNZ
« Reply #5 on: March 31, 2015, 19:43:45 pm »
I was given a 'replacement' yesterday. My only trouble now is that the factory manual only told me how to remove the fingers to get this off, so I did only to find that I could have just moved the springs to get it off.  The instructions on resetting the fingers and height in the manual aren't great....!
Dual Carb 36hp
