September 26, 2026, 20:59:22 pm
| | |-+  Narrowing a beam ?
Author Topic: Narrowing a beam ?  (Read 10277 times)
71CALRIPPER
« on: September 10, 2007, 08:10:27 am »
Got hold of an ally Beam for my Project, i am running BAD disc with 4 pot willwood calipers up front. they dont push the ofset out and would be running 3.5 inch Weld wheels. Now do i need to narrow the beam or with the small rims will it be enough to tuck the rims under the wing enough?
Thank you for any thoughts
Rob
benssp
www.callookvw.com
« Reply #1 on: September 10, 2007, 08:54:46 am »
what's the off set of the wheels rob? Grin
www.vwheritage.com  My Job
YMCA
71CALRIPPER
« Reply #2 on: September 10, 2007, 09:05:26 am »
ah good point will be 0 of set Smiley
63 ripper
« Reply #3 on: September 10, 2007, 09:13:04 am »
if they are zero offset (like the c/lines you had and the same as "bubble" ercos) then the calipers won't clear. those bad calipers are massive. you would need big spacers and yes a narrow beam.
JG54
71CALRIPPER
« Reply #4 on: September 10, 2007, 09:27:04 am »
ahhh forgot about that, right so if il find some with minimal ofset welds but you still think i may need to narrow it? pain in the ass to do Smiley
63 ripper
« Reply #5 on: September 10, 2007, 09:39:56 am »
have a read of this
http://www.cal-look.com/forum/index.php?topic=21343.0
charlie 53 is local to me  Wink
if you don't use dropped spindles and if those BAD brakes don't increase the track the welds should work. don't you want to swap wheels around though ?
JG54
benssp
www.callookvw.com
« Reply #6 on: September 10, 2007, 09:46:19 am »
It will also be worth speaking to pete shattock about narrowing them, also modding the frame head to get your caster angle as Pete say's it's a bit of a pain to use shims with them as the beam brackets are solid and not hollow pressed jobbies like the orignal Grin
YMCA
71CALRIPPER
« Reply #7 on: September 10, 2007, 09:50:30 am »
ahh good info, will need to make sure i do it right then , Gulp , want to have it bloody rolling around by december. So i can go to south africa on my wheel hunt knowing i got somwhere this year.
Oh BTW the 63 now Rips propper. Twickenham is now fully awake Smiley
Thomas 356
« Reply #8 on: September 10, 2007, 14:01:18 pm »
Hey if you need and narrowet beam see  http://.www.teamangoraracing.dk
Best Regard
Thomas 356
Thomas 356
Menber Of  Boulevard Cruiser´s
Driver of the Nasty Gray (Back In Fridolin style)
www.thenastygray.blogspot.com
61ragtop
« Reply #9 on: September 12, 2007, 01:32:32 am »
Rob
If you need Nick Butlers phone number again give me a bell tomorrow, hes only 20 mins from you and can prob do your beam for you in a few days. Problem solved Wink
Glad your sticking with the oval, i need some friendly competition to keep my project on track.
james
