September 23, 2026, 01:24:35 am
Hurst line lock on my '54 oval
Topic: Hurst line lock on my '54 oval (Read 4271 times)
chateau la fete
June 07, 2015, 20:51:06 pm »
Just after as much info as possible on a hurst line lock install on my '54 oval. Do I go from the inlet of the hurst line lock to my dual master cylinder and use the two oulets of the hurst line lock to my front brakes, one for the left brake and one for the right brake? Does it matter what outlet from the dual master cylinder I block off? Or do I use one outlet from the hurst line lock to a 'T' piece, then to the front brakes? Do the outlets of the hurst line lock need to be lower than the outlets of the dual master cylinder (because of gravity)? Cheers for any input
Re: Hurst line lock on my '54 oval
June 07, 2015, 20:58:30 pm »
plug either outlet on master cylinder, use line lock to split to both front brakes and you can mount it higher than master cylinder and it bleeds just fine, just did it that way on my 67
chateau la fete
June 08, 2015, 06:38:19 am »
Ok, thanks
So no 'T' piece
Also is there a particular way in bleeding, I have heard of a few issues with the operation of the line lock
Erlend / bug66
Global Moderator
SCC Event
June 08, 2015, 08:17:10 am »
The line lock works like a "T-piece".
Just bleed the brakes. It will flow through the line lock as long as it's open (no power)
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
chateau la fete
June 08, 2015, 13:30:27 pm »
I did think that, the instructions just look a bit random!!
