October 21, 2026, 21:21:05 pm
352324 Posts in 28959 Topics by 6927 Members
| | |-+  Fubar 64
Pages: 1 ... 3 4 [5] 6 7 ... 13 Print
Author Topic: Fubar 64  (Read 305135 times)
vwhelmot
« Reply #120 on: July 07, 2015, 09:38:04 am »
So then it was a case of welding up all the holes made when I had drilled out the spot welds on the cross member, and generally prepping the panel for its new home.
Drilling holes in my newly repaired firewall wasn't nice
I also made a new dimple in the modified section to even things out
Left my mark before welding it on.
Even weld through primer sometimes needs to be scratch off for the best results
Seam welded on to
Seam tidied up
« Last Edit: July 07, 2015, 09:42:31 am by vwhelmot » Logged
« Reply #121 on: July 07, 2015, 21:21:35 pm »
two questions:
1 - what weld through primer are you using
2 - how are you finishing the welds?  What type of sander is it etc
vwhelmot
« Reply #122 on: July 07, 2015, 22:10:12 pm »
Upol weld 2
I linish the weld with a 1" belt sander and then use a random orb sander.  All of my tools are Makita.  I know them inside and out.
vwhelmot
« Reply #123 on: July 09, 2015, 10:55:25 am »
So next on the list was to sort the crumpled pressing on the right channel, so I cut out the section and welded in a new one.
Sorted
Onwards to the lower front quarter. Now the Virtanen panel I bought is a good pressing but there was a few differences as it was for an oval , so I modified it to the later sixties spec.  I cut the end off completely and grafted on a genuine section I had, so that it lined up perfectly
I had to be very careful to get the measurement and cut right
Right shape and thickness
Nutsert started like this, wrong for my car.
Super Tool  Grin
Genuine nutsert
Silver soldered in
The bottom didn't flow properly either so I added some metal
Matched from the other side
I needed to trim it down after this shot
vwhelmot
« Reply #124 on: July 09, 2015, 11:06:12 am »
As I wanted a nice invisible repair both inside and out I knew there would be an issue with metal thickness and I was right. Over the years of abuse, rust, blasting, scraping etc the inner quarter had gone thin, it starter from the factory as around 1mm sheet and mine was on average .7mm
Again welding thick to thin does not work especially if you want a nice finish on the inside too. The new repair panel was 1mm
I thought about this problem for a while, what could I do.....?
The only way around it and I know this sounds crazy but I had to make my new panel thinner, so I put it on the linisher ( basically an upside down 4"belt sander) . You can see where I sanded the whole side down.
Got it down to a nice even .73mm
« Last Edit: July 09, 2015, 11:17:57 am by vwhelmot » Logged
vwhelmot
« Reply #125 on: July 09, 2015, 11:15:10 am »
I epoxy primed the inner door pillar first like the other side
Spent a long time panel prepping
Then started the welding
All the spot welds are just temp plugged for now but the main join is getting there. This took an age.
Inside nearly done
Bare metal
Much nicer than before
No filler
Getting to the inside here was hard
Happy days  Grin
« Last Edit: July 09, 2015, 11:18:43 am by vwhelmot » Logged
mychatype3
« Reply #126 on: July 09, 2015, 13:28:47 pm »
Wouw insane metalwork, love it
1968 fastback "in resto"
1970 Westfalia from the States
« Reply #127 on: July 09, 2015, 22:49:47 pm »
Those virtanen panels look nice - i remember when the Veng panels had that full closing piece in for the bottom of the quarter panel - now it's just a slot! Great work as always.
vwhelmot
« Reply #128 on: July 11, 2015, 09:18:58 am »
Ha, veng stuff is so shit, none of it fits right!
To get away from the welding etc here is some of the other stuff I`ve been doing . All the bolt on panels have had their own various issues, the wings that were on the car when I bought it back were Day moulding ones. They are great quality and I was going to reuse them and had thoughts about getting the insides gel coated too but for a show car fiberglass doesn't cut it.  Finding a nice set of original wings is getting harder, especially the fronts.  I got a pair off a well known person in the vw scene, they are slightly earlier ones so the indicator holes are wrong for my year but I am going to fill those in anyway and run us spec headlamps. They needed quite a bit of straightening, some of the dents were very difficult to get out but after a lot of beating they are good now.
I had to heat this area up to get it straight
It split
After welding etc
I was not 100% sure if the bonnet on the car was original vw , it fitted ok but I had a nagging doubt that it wasn't so I did a deal with the same well known vw person for my old day wings and bonnet for the two fronts and a genuine bonnet.  We arranged to meet one weekend to exchange the panels but when he turned up with the bonnet I was a bit cheesed. He actually turned up with two , one was peppered with stone chips . had some splits here and there , some dents too and there was this one  Roll Eyes
So I bought both  Grin     This rusty one had been previously blasted and for some reason just left with no primer or protection whatsoever. Running my hand over it there is no dents and no splits or cracks, just rust.  I was confident I could get it back so to start I ran a DA sander over it first , just to get the worst off.
The trim holes had been welded and leaded. I will put the holes back in.
Outside for a bit of rust removal  Grin
Other bonnet which maybe for sale soon !
No substitute for blasting
This is the ex rusty one
Other one came up good too
Underseal took an age to scrape off
Came up nice
vwhelmot
« Reply #129 on: July 11, 2015, 09:24:36 am »
vwhelmot
« Reply #130 on: July 11, 2015, 09:30:53 am »
The wings like I said had numerous issues, dents and bent etc. Took a week off to massage them out
Doesn't look bad here but it was out of shape
Large area misshapen
Came out nice
Showing the high and low spots on the same wing
Almost there
vwhelmot
« Reply #131 on: July 11, 2015, 09:41:37 am »
Other side had more issues
You cant see it but the whole lip wing edge had been pushed in and was out of shape
Difficult to get straight
Top had a crease
It had stretched too so I had to shrink it with heat
After shrinking and a quick layer of primer to check
vwhelmot
« Reply #132 on: July 11, 2015, 09:52:23 am »
Getting rid of some of the factory pressing marks. Suppose I could have used a bit of filler here but that aint my style
Still work to do on this wing, the mounting flange needs welding etc
vwhelmot
« Reply #133 on: July 13, 2015, 10:44:37 am »
The passenger door that was on the car turned into a bit of an issue. After blasting it looked ok to start of but at closer inspection the skin had stretched and was out of shape and I knew that without many many hours of work it still wouldn't be ok to use. I had worked on the door previously, it was a rust free cali door but was bent when I got it and I remember I had to cut the window frame to straighten it. Maybe the whole door was under tension or something and the blasting process compounded the fault causing metal the stress relieve maybe.
Looked Straight
Being that its a 65 model, these doors are pretty rare in that they only made them for two years so finding another one was going to be a prob.   Luckily FBI had one advertised on evilbay so I bought it now !  It looked on the advert to be a really nice one until it arrived.........
It looked like it had been driven over with a forklift truck or something.  Angry Sad Sad Sad
I was gutted
« Last Edit: July 13, 2015, 10:48:33 am by vwhelmot » Logged
vwhelmot
« Reply #134 on: July 13, 2015, 12:13:10 pm »
I knew I would get nowhere with the courier company but fbi sorted me out with a discount fairplay, fantastic service.   I knew the corner had had a big sqeeze and there was no way of straightening the inner panel so the only way to fix it was to cut it out.
I had another scrap door for the section I needed
Drilled out the spot welds
The reason why most doors rot from the corner is this lump of sealant that they used. Its just a water trap.
Blasted
Fortunately the skin was undamaged and when I removed the damaged inner section , the outer pretty much sprung back into shape
Tacked
Lined up correctly
I was extra careful blasting this one!
« Reply #135 on: July 13, 2015, 19:52:40 pm »
I love this thread. Where did you get those mini adjustable jaws
vwhelmot
« Reply #136 on: July 13, 2015, 20:00:10 pm »
Thanks lids
Here
http://pages.ebay.com/link/?nav=item.view&alt=web&id=121486566962&globalID=EBAY-GB
« Reply #137 on: July 13, 2015, 20:49:41 pm »
thank you, just ordered some Smiley
Mirco Jufer
« Reply #138 on: July 16, 2015, 19:01:10 pm »
Awesome Work!! Love It Smiley
« Reply #139 on: July 16, 2015, 21:43:08 pm »
Great work on that door. Will you work on other people's cars? Grin
vwhelmot
« Reply #140 on: July 16, 2015, 23:13:45 pm »
Been thinking about doing other work when this is finished, but would have to travel to North Wales, suppose it's not the end of the world! I Would have to call it Custom Creams too.  Smiley
Thanks for the compliments by the way.
vwhelmot
« Reply #141 on: July 17, 2015, 12:56:10 pm »
Onto the front and again it was a proper mix of wrong shape panels and modifications. I`m replacing the front beam for one that doesn't need body mods so I could get rid of my previous cycle chain guards !  Cheesy
It seemed a good idea at the time to modify the bodywork instead of the suspension  Embarrassed
Finding the correct replacement front clip sides would prove to be a bit of a problem. I placed various wanted ads on some sites and had a few replies. Some folk on the Samba wanted to charge me up to $1000 to ship the two side panels to the UK  Roll Eyes but fortunately I came up trumps with a near side one on VZI and then a while later Alex Taylor from Defcon3 sorted me out with both front panels off a UK car.   All three panels needed work so I chose the best and took it from there.
Super cycle fenders
Lovely spot of welding
Drilling out
vwhelmot
« Reply #142 on: July 17, 2015, 13:07:58 pm »
I blasted the panels and drilled out the tank support and bumper mounts etc as I knew there would be rust behind them. I was right, bet there are plenty of show cars out there with rust behind here  Cheesy
It was pretty straight but thin in places. This is the UK one
Nice on the outside....
Shit on the inside
vwhelmot
« Reply #143 on: July 17, 2015, 13:19:17 pm »
More
Its strange but there are two captive nuts that are different than the rest. Its more square for some reason. I had a couple spare.
Silver soldering it back on
Lower one
Had your horn mount off recently?  Grin
This is the near side Californian panel. It was in good shape
I cut the front off and quickly offered up the replacement
It lined up nice
Wing on to check
Everything was good
vwhelmot
« Reply #144 on: July 17, 2015, 13:28:40 pm »
What was left of the original tank support was removed
Plenty of rust
Blasted clean
The UK panel was holed and thin so I had to replace various sections. I cut the repo panel up and used that as donor panels.
Super tool
Matching up to the cali side
Welded on
W
vwhelmot
« Reply #145 on: July 17, 2015, 13:33:00 pm »
I offered up the new tank support which I modified a bit by adding some dimpled holes for that custom touch.
This was encouraging, the spot weld holes all lined up
vwhelmot
« Reply #146 on: July 20, 2015, 10:01:45 am »
The UK panel needed more work
I used the old panel as a donor
Neater than factory. This area is always crumpled from the factory
vwhelmot
« Reply #147 on: July 20, 2015, 14:48:07 pm »
There was also a section which was thin so I cut that out too . I had to make a buck to form the panel in one piece.
Cleaned up the inside more.
Almost ready to start attaching the front on for good
Tacked
Kept a check on this
So much time welding this on and being extra careful with dressing the welds after
No filler
vwhelmot
« Reply #148 on: July 21, 2015, 13:03:08 pm »
After welding the tank support on I trimmed the lip so that it flowed straight
Cheeky pic through the glove box
vwhelmot
« Reply #149 on: July 21, 2015, 13:22:08 pm »
Onto the other side and I knew this was going to be more of a challenge as mixing a new style quarter with an old front would be difficult to get to look right. There was numerous differences.
In the pic you can see I had to add a piece to the new front as it had been previously cut short.
Notice too the scorch mark, this is where I had to heat up the metal to get rid of the bulge pressing for the twin brake master cylinder feed pipes to pass between the tank and the quarter. This took quite a while to get right as the metal wasn't playing ball to start off with.
Like I thought , this side was proving to be a pain  Cheesy
See if you can spot the other problem
