June 10, 2026, 01:34:59 am
Latest Member: mvptkfjb
| | |-+  Fubar 64
Pages: 1 ... 4 5 [6] 7 8 ... 13 Print
Author Topic: Fubar 64  (Read 273037 times)
karl h
« Reply #150 on: July 22, 2015, 07:16:10 am »
top profile of the panel is different?
vwhelmot
« Reply #151 on: July 22, 2015, 07:56:50 am »
  Correct  Grin
« Last Edit: October 10, 2017, 15:58:59 pm by vwhelmot » Logged
vwhelmot
« Reply #152 on: July 22, 2015, 09:29:40 am »
I would sort that problem later but for now I had some other stuff to do.
The speedo cable clip was wrong for my car so I modified it to the correct sixties spec
I did think about cutting it out and welding this genuine section in but I came up with another idea
I lined up the old section and sprayed some primer through it to get an outline
Cut two slots
I then made a form to replicate the bridge
Tacked the former onto the quarter
« Last Edit: July 22, 2015, 10:32:38 am by vwhelmot » Logged
vwhelmot
« Reply #153 on: July 23, 2015, 11:36:39 am »
Next I had to do something about the crappy factory pressing
Matched to the other side
Tacked on
Wing on to check
Seems to fit ok
vwhelmot
« Reply #154 on: July 23, 2015, 12:09:02 pm »
Problem I would have to sort later
Nearly done
The black line is where I made a cut
You can see the problem here
Sorted
vwhelmot
« Reply #155 on: July 24, 2015, 09:41:28 am »
Tank support welded back on
Factory spot welds still there
Time to do something about the crappy factory bumper mounts
Next problem  Grin
vwhelmot
« Reply #156 on: July 24, 2015, 13:13:30 pm »
Looking at this there seems to be a common issue, I could have easily welded it all together and hammered it into place but it would have looked crap so I spent a lot of time making it good
The only way was to make a pie cut and add a section in
I was so careful to get this right, the bonnet and wings were constantly on and off
Autocraft front valence fits nice
Obviously had to do the same on the other side
Other bumper mount
« Last Edit: July 24, 2015, 13:24:12 pm by vwhelmot » Logged
vwhelmot
« Reply #157 on: July 24, 2015, 13:23:15 pm »
Well folks, this is it for now. Like I said I just wanted to show the amount of work that's gone into my bug so far. I`ve been doing many many more hours work on all the other details which I will keep to myself for now. I`ve done more bodywork and there is still lots to do but you get the picture?!  Its got to be ready for paint by spring next year and then its off for its new coat of sea blue by someone who knows what it takes to paint a show winner.  Cheesy   Cheers for the compliments
Parting shot. Bye for now...
« Reply #158 on: July 24, 2015, 13:49:13 pm »
Well done. Amazing work. I loved it the first time round so can not imagine how good it will be this time.
Gaz1
« Reply #159 on: July 27, 2015, 12:32:21 pm »
Stunning work mate , it's coming along nicely   Grin
« Reply #160 on: August 01, 2015, 18:10:41 pm »
Dam nice work ! Great detail !!
« Reply #161 on: September 09, 2015, 21:01:23 pm »
I need to get my fix..
What's up? Any update?
vwhelmot
« Reply #162 on: September 10, 2015, 08:30:17 am »
 Grin
I`ve been doing lots to it, the body is back on the pan for mock up,  fitted the spare wheel tray and fitted the gearbox and motor. There has been a tonne of work with the engine mock up side of things, I`ve had to fab up a new traction bar as the old one didn't fit because of the exhaust, cut and remount the whole trapeze bar, build a stainless 304 muffler , create a three piece removable rear valence and then I had an issue with the deck lid gaps which I am now nearly finished in fixing that.  I`ve been doing lots of custom bits like steering column mods, mag switch location etc.    Final bodywork will start prob around November which will give me plenty of time to get it ready for paint next spring.
I modified the lip on the nos spare wheel tray so it flowed nicely, no gaps.
Also doing lots of detail bits like this, so many small areas that need attention, its unreal
Defrost delete, ugly dash part beautified  Grin
 Thank you so much for the kind comments, its appreciated. Cheers
« Last Edit: January 10, 2017, 12:27:27 pm by vwhelmot » Logged
« Reply #163 on: October 14, 2015, 07:20:50 am »
Any more updates? I`m eager to see and to learn more from your fantastic work.
-BB-
vwhelmot
« Reply #164 on: October 14, 2015, 09:51:02 am »
 For the past two or three months its been all about the engine mock up. I must have installed and removed the block about twenty bloody times. You know how it goes, to fit this, the carb has to be mounted, to clear that ,the fan housing has to be mounted ........
I`ve realised that I`ve wasted a lot of time polishing lots of parts that were previously fitted only to realise that I will not use them again. The tall manifolds have gone, I must have spent three days smoothing and polishing those only to find that that age old problem of the stack to foul the lid.  Also I`ve been having a few issues with the deck lid fit. The car was involved in a minor accident way before I bought it the first time in the nineties, the previous owner had reversed into a waterboard truck and pushed the offside corner of the deck lid inwards hitting the dynamo in the process. the damage caused was cosmetic but I had not reckoned with the fact that the offside engine bay side was pushed downwards in the event.   The gap between the lid and body on the nearside was perfect but the offside there was much larger.
Perfect
Really bad
Now , I tried to fix this by panel beating the body upwards which worked to a degree but I wasn't happy with the fact that some filler would have had to have been used so I cut it out and replaced the corner with a new section from a later donor car.
Gap at the top was great
I tried using my dent puller
No luck so I cut it out
It would have took a lot of filler to fix this  Grin
Donor section from a late bug
Quickly fitted, one hell of a difference
Surprise surprise the wing captive nut was wrong so out came the trusty super press tool
Genuine nut
See the difference in the shape
Part way in
Mucho bettterrer
No filler
vwhelmot
« Reply #165 on: October 14, 2015, 10:03:59 am »
Other little but important jobs like this too. Trying to find the sealing clamping strip on the rear valence proved to be a challenge until Autocraft engineering sorted me out with a new strip. It was sort of bent to a shape but took a bit of careful massaging to fit. The old one was never going to look right.
Also been working on a cabrio deck lid which I will get ready for paint so I`ve got the choice of two lids. Exhaust is now finished, the oiling system is finished with a new cooler etc, all the fuel lines are done, the motor is stripped and ready to be taken for a full rebuild and a capacity hike and cam change , many parts are ready for the chrome.....
I`m finishing all the tiny jobs that need doing before I start to prime and body prep and panel fit. There are a few decisions about some other stuff to be made and I`m having trouble making my mind up what to do. These changes radically change the look of the car.... Shocked
MickO
« Reply #166 on: November 01, 2015, 13:22:35 pm »
Very inspiring work!
Stupid question from a beginner: What type is the yellow primer that you use after blasting?
« Reply #167 on: November 01, 2015, 17:31:35 pm »
He answered that earlier in the thread
vwhelmot
« Reply #168 on: November 01, 2015, 17:58:45 pm »
The yellow is an ordinary etch primer, 1:1 mixed with activator
Cheers.
Clatter
« Reply #169 on: November 02, 2015, 06:11:38 am »
Upol weld 2
I linish the weld with a 1" belt sander and then use a random orb sander.  All of my tools are Makita.  I know them inside and out.
Oh, my, this is lovely to behold... I'm floored.
So much detail!
Care to share a bit more of your methods?
Am i to believe that you do all of your rough dressing of welds with the little electric Makita belt fella in the pic here?
No stone grinding wheels at all Huh
I am baffled how you dress welds down inside right angles and tight crevices and such..! Shocked
Do you have a picture of your DA sander?
It's also electric?
What grits do you prefer for these?
-Also-
You are spot-blasting up high there, or forking the thing down every time?
I could see blasting up there making the mother of all messes..
Learning SO much here.. Pretty much spent most of today studying this.
Thanks for taking the time to document so thouroughly.
vwhelmot
« Reply #170 on: November 02, 2015, 08:58:58 am »
Upol weld 2
So much detail!
Am i to believe that you do all of your rough dressing of welds with the little electric Makita belt fella in the pic here?      .................    Yes I do 99% of the rough dressing with the belt sander 40g then 60g belts
.................The only time I will use a grinder is when I need to make a cut or some serious rough dressing. You can easily slip and do some damage with a grinding cutting wheel, yes I said cutting wheel too. I never use a thick grinding wheel as the is very little control with those, a thinner cutting wheel used on its edge is better but don't grind on its underside as cutting wheels used for grinding can explode, the strength is at the tip. Tight corners etc are accessed using a die grinder with a burr first.
It's also electric?
............Its just a 5" Makita elec da sander, I use 60g or 80g
-Also-
...........Yes I spot blast and have to clean up after, its easier than lifting the shell up and down on the mez floor!
...........Thanks for taking the time to document so thouroughly.
Thanks and no worries, just make sure you enjoy what you do!
vwhelmot
« Reply #171 on: November 02, 2015, 09:02:04 am »
Built the frame at the end of last week. A year and a bit too late me thinks  Cry
vwhelmot
« Reply #172 on: November 09, 2015, 12:26:31 pm »
Redoing work I did a year ago  Smiley  It really bugged me that this pressing I made was not the right shape so I repaired the rusty cut one from the states.
vwhelmot
« Reply #173 on: November 09, 2015, 12:30:18 pm »
... and made my own weber windows
vwhelmot
« Reply #174 on: November 21, 2015, 10:01:35 am »
A few pics of the re repair of the boot floor edge. Not an easy place to get too to finish it properly.
I had to weld on a new seam as it was missing completely
Part way through
Job made easier
Next problem was that the seam didn't flow right. Had to do something about it
Added a fill in piece
finished
vwhelmot
« Reply #175 on: November 21, 2015, 10:06:04 am »
Modded the hinge mount. Ugly as standard.
broen messiaen
« Reply #176 on: November 21, 2015, 12:26:19 pm »
very impressive!
could you show how you did the mounting of the rear apron? i see some kind of fastener system to mount it.
thanks
karl h
« Reply #177 on: November 23, 2015, 09:27:06 am »
as always - watching in awe! i have no fucking idea of how you get it that clean, i tried but i never even come close to your work....
vwhelmot
« Reply #178 on: November 23, 2015, 13:23:03 pm »
Thanks, just takes time and lots of it.  As for the rear valence, I will show how I`ve done it a bit later. Took a bit of head scratching to get it right.  Grin
Deanodynosaurs
« Reply #179 on: November 24, 2015, 17:59:48 pm »
F*ckin Hell!! Your attention to detail is awesome, and you metal working skills are amazing!! Proper respect to you. Smiley
Dude  Cool
