September 22, 2026, 14:55:36 pm
| | |-+  Fubar 64
Pages: 1 ... 5 6 [7] 8 9 ... 13 Print
Author Topic: Fubar 64  (Read 298928 times)
vwhelmot
« Reply #180 on: December 05, 2015, 20:17:04 pm »
Cheers Neil , if it turns out anywhere near as good as your looker then I will be happy.
While the bodywork has taken up all my time and it's still ongoing, all the other parts are being worked on in the background. The odd couple of hours here and there, lunch times etc are being used for all the other stuff that needs doing. A full engine strip and rebuild was reqd even though it ran with no problems or issues, I just wanted it freshening up and a hike in capacity and power will go down well. Cosmetically it needs a tonne of work, linkage and manifolds and a whole host of other parts are being changed too.
  The manifolds needed changing because the tall skat ones made the stacks foul the decklid and that just won't do. I bought a set of unbranded short ones and set about match porting them to my Jeff Denham heads. Shame really as I spent an age polishing the tall ones Sad
Copying the port shape
Bought the necessary tools
And got on with it
They were rough castings
Very rough!
Got there in the end
vwhelmot
« Reply #181 on: December 05, 2015, 20:31:16 pm »
The strip revealed a few issues, lifters, cam and lifter bores are pretty worn, crank and rods look ok and the case needs a little line bore. The Denham heads will be checked over. I'm going for a hike in cc, 2276 is the order of the day.
Ongoing story...
« Reply #182 on: December 05, 2015, 20:47:06 pm »
Nice work. What tool and tool bits are you using to do the manifolds?
vwhelmot
« Reply #183 on: December 05, 2015, 21:04:35 pm »
Cheers. I used a bergen long burr set but to be honest a short set did the job. HPS supplied the sanding roll set. Not cheap stuff but very handy! Got a blue point die grinder to use with the long burrs so I could regulate the speed. Mainly used a Mikita electric die grinder for most of the job.
« Reply #184 on: December 05, 2015, 21:30:21 pm »
Great, have been looking for an electric die grinder for a while. What model is yours?
vwhelmot
« Reply #185 on: December 05, 2015, 21:36:35 pm »
It's a really old one mate. 110v which I run off a transformer.
« Reply #186 on: December 05, 2015, 23:05:21 pm »
Ok, that's cool. I've google'd a few  Grin
£30 for the Scat Traks?
vwhelmot
« Reply #187 on: December 05, 2015, 23:19:02 pm »
They are on my mantelpiece. Smiley
« Reply #188 on: December 06, 2015, 10:12:00 am »
vwhelmot; what is the area at the tightest point in your new manifolds compared to the cylinder head intake channel and valve size? You should try to avoid thight areas throughout the intake channel since you do not want a second venturi.
Best rgs
BB
vwhelmot
« Reply #189 on: December 06, 2015, 11:04:09 am »
I've done about as much porting on these manifolds as I can without having to weld them. The tightest area I suppose is the curve on the inside.
Deanodynosaurs
« Reply #190 on: December 07, 2015, 01:12:30 am »
Dude, its already better. Honestly, the standard of metal work and attention to detail on this car is another level. Smiley
If I ever do another car this will be the standard I aim for. Smiley
Dude  Cool
Rocket Ron
It's old school for a reason
« Reply #191 on: December 07, 2015, 08:25:59 am »
I've got a nice 110v one if you need to borrow it
Ta Ron
« Last Edit: December 09, 2015, 09:13:49 am by Ron Elliot » Logged
13.12 @ 101.84
Grooving out on life
« Reply #192 on: December 07, 2015, 08:32:26 am »
Thanks Ron  Grin
vwhelmot
« Reply #193 on: December 13, 2015, 01:05:31 am »
Fourteen months ago
It's been a blur! Smiley
vwhelmot
« Reply #194 on: December 13, 2015, 12:29:11 pm »
When it came to the channels , I knew that the closing plates were all wrong. Wrong shape and wrong pressing. I knew it would be a bit of a pain to drill out all the spot welds but it had to be done. 95 in each closing plate, my blair cutter did the trick.
Check out the horrible pressing, it wasn't even a one piece panel
The way the crossmember lip on the outside is wrong too
Steve Hook made me a pair of panels that are slightly different. The way the panel angles forward is different on the later channels , the early pressings had more of a curve so Steve made mine a bit wider at his point but I knew I would have to add more metal to this area to accommodate.
See here
Blasted on the outside, rust on the inside
« Last Edit: December 13, 2015, 12:31:05 pm by vwhelmot » Logged
vwhelmot
« Reply #195 on: December 13, 2015, 12:41:36 pm »
From the factory, there are some dimples that are pressed into the lip like these
Mine didn't have any. So I made a simple tool and pressed some in
I then made a quick blast cabinet, it had to be done and I was prepared for the mess afterwards
Also blasted and etch primed the new panels too
Starting to line things up
More metal needed
Joy
vwhelmot
« Reply #196 on: December 13, 2015, 12:46:27 pm »
Crossmember was welded to the inner lip of the channel then the closing panel welded on top
Sorted
« Reply #197 on: December 13, 2015, 17:53:36 pm »
Fourteen months ago
I think I prefer the 1st picture Shocked Cheesy
Seriously stupid amount of work you have done, well done Cool
vwhelmot
« Reply #198 on: December 13, 2015, 18:21:35 pm »
So do I Smiley haha
Onto the other side it was much the same story, it also gave me the chance to remove the heater tubes too and the amount of glass dust that was trapped inside was an eye opener
Just from one side
More spot weld drilling
Had one of those rare moments when I had drilled out all the spots in the right place. Stuck the chisel in and it just fell apart. Happy days
Goes to show where rust lurks
So, after filling up the whole are with crushed glass, it was onto cleaning up all the lips and getting the new panel ready for fitting. Welded the crossmember to the channel like this.
Clamping up the rear. It's such a strong structure when finished. Great design
Took a long time to make sure everything was straight. The body had been placed on the pan a few times to align up the bolt holes
Finished
« Reply #199 on: December 14, 2015, 00:32:20 am »
You have the patience of a saint. Well done.
vwhelmot
« Reply #200 on: December 14, 2015, 08:37:51 am »
I`m single  Grin
karl h
« Reply #201 on: December 14, 2015, 08:52:00 am »
running out of superlatives here....
vwhelmot
« Reply #202 on: December 15, 2015, 15:29:45 pm »
Cheers  Cheesy
  Getting the front valence on was pretty straight forward, welding the seal clamping strip is a bit of a pain, its very hard to attach it neatly and to bend it right. I found the best way was to run a steel rod up through the strip and after that it was a lot easier to bend without kinking it. I welded it from behind too. The valence itself is an Autocraft engineering item. Its a nice pressing, fitted well but I did clean and straighten some of the edges a bit. It would be nice if they offered one with the seal strip already attached but I guess they know that's its a pain to do.
Wings on to check fitment
Edge needed trimming straight, it was a bit off
The factory used to braze the corner on like this so that what I had to do
One side done
Sorted
Even this small job took a whole day, roughly 8 hours to do and that was not including welding on the seal strip because I did that the night before. Its crazy where the time goes.
This is really it for a while, I have just the wings to work on and a small job on one of the doors and after that its getting it prepped for paint.  There is lots I haven't shown but I will update next year.
Happy Christmas to everyone!   Grin
Matty c
« Reply #203 on: December 29, 2015, 23:05:51 pm »
Awesome workmanship dude! I have a question regarding the sealing strip on the rear valence, I'm about to do the same thing & was wondering how you managed to put the curve into it without any puckering on the inside edge? I got my strip from autocraft too but it came completely straight   Roll Eyes
67heaven
vwhelmot
« Reply #204 on: December 30, 2015, 10:39:31 am »
I managed to find a length of steel rod that I could insert into the sealing strip so that when you form it and bend it etc it will not kink. I bent it as I welded it, little at a time. After I finished , the dowel rod could be just pulled out easy. The job still took time and with the rear valence make sure the strip is high enough not to foul the decklid. Mine took two attempts Smiley
PiL
« Reply #205 on: December 30, 2015, 19:38:24 pm »
What spot weld drill/ cutter do you use? I'm looking for a new one and could do with a recommendation.
Cheers Paul
Check out the build of my new race car at:
http://pilsvw.blogspot.com/
vwhelmot
« Reply #206 on: December 30, 2015, 20:31:24 pm »
These are the best I've come across, they work best when instead of using a centre pop , use a small drill to make a dimple first. This way the cutter won't wander at the start.
http://www.ebay.co.uk/ulk/itm/351041392853
« Last Edit: December 31, 2015, 18:40:54 pm by vwhelmot » Logged
vwhelmot
« Reply #207 on: January 02, 2016, 19:12:06 pm »
Found some pics
vwhelmot
« Reply #208 on: January 24, 2016, 20:47:50 pm »
I've got to admit it , I hate working on bug wings. They are just a pain in the arse. You can't clamp them down while working on them easily, if you need to do detail work on them like grinding/ cleaning the mounting flange it's almost impossible to get light to see what you are doing. As soon as you cut them they move etc so all in all its been a chore.  From the start I vowed to get an original set of genuine wings. As you know getting a decent set is getting really difficult and when you do 99% of the time they need work. Even nos ones variably need some sore of dent repair or blasting due to storage rust etc.  The rears have been the most work, I've ended up restoring two sets of rears. I have bought six rear wings to find that I can only use two. I bought what I thought was a nos right side only for it to turn up and I straight away had doubts to whether it was genuine. The return lip just looked wrong etc. The second set turned out to be a IGP set , repo. To be honest these ones fitted great and needed minimal work and I spent quite some time making them perfect. The only problem was that I knew they were repo and they were slightly wrong for the year in that the mounting flanges were dimpled like on earlier cars. They would have stuck out like a sore thumb and I should not have wasted so much time.   The third set is the ones I'll use. Bought off here from Rob the Manx , they too needed work but they fitted and looked right and are genuine.
IGP repo wings. They fitted great
Spent some time cutting out and making good all the untidy lips and returns.
Front was too long so I modded it
Blasted them
Then decided not to use them. Smiley
vwhelmot
« Reply #209 on: January 24, 2016, 21:01:01 pm »
So onto the genuine ones. Spent a lot of time trimming down the return lips and basically doing the same work over again. I had already lost over a weeks worth of evenings on the repo set so I wasn't going to look forward doing it again but hey ho.
Factory pressing isn't always nice. Mass produced after all.
Making sure that the lips match side to side.
Then filling in the US spec over rider holes
Other side
Fronts still needed work. Like this.
New sections welded in.
And welding up the indicator holes which were huge. Careful welding reqd here to avoid distortion.
Making sure the running boards fit took time too.
It turned out that the ones on the car were genuine. I've blasted them and bought new genuine covers.
Been fitting doors and bonnet too.
