October 21, 2026, 22:23:58 pm
352324 Posts in 28959 Topics by 6927 Members
| | |-+  Fubar 64
Pages: 1 ... 11 12 [13] Print
Author Topic: Fubar 64  (Read 305163 times)
Andrew
« Reply #360 on: April 07, 2018, 15:19:23 pm »
Agreed, amazing job, fantastic dedication, almost needs to be on permanent display, but even better driven.
vwhelmot
« Reply #361 on: April 07, 2018, 15:52:56 pm »
 Cheesy thanks. I’ve always wanted to win bos at volksworld, that’s the reason I’ve pushed myself to do what I’ve done. I’ve just made every part to the best of my ability and if I thought it wasn’t good enough then it didn’t go on the car. Since the show there are a few things which I will redo but I’m happy how it’s turned out. I can understand why cars like this don’t come up very often, the money and time invested is toe curling and it took major commitment from me to stick to my original idea.  It’s great that people also seem to like it, projects can go horribly wrong, vision can wane and standards can drop , people can invest lots of money into something and it still can look like a dogs dinner through something simple like colour choice.
Thanks people
vwhelmot
« Reply #362 on: April 09, 2018, 09:40:15 am »
The front beam is a Limebug 3" narrower item. Really nice quality to be honest but I couldn't just paint it and bolt it on. I spent quite some time modifying it, first lopping off the ugly steering damper mount then setting to it with a die grinder and smoothing every weld down. This took many hours but it was worth it.
Untitled by lyndon creamer, on Flickr
I also drilled holes in the shock towers and then had to add strengthening supports up the sides because I had weakened it  Grin. I really prefer the look though. I primed it and blocked it many times to get the result.
I painted it myself with 2K black
Fitted up a billet mount. Much nicer.
Fitted up the arms after many hours of smoothing and capping the ends. They took two attempts to chrome properly.
Even trying to fine stainless lock nuts and finding a chrome cap took ages
The shocks are spax adjustables that I made to look like red Konis  Smiley  They too took a shed load of work to smooth the mounting rings etc.
Fitted up with ARP bolts and the spindles etc
I was starting to enjoy watching come together at this point
karl h
« Reply #363 on: April 09, 2018, 12:08:48 pm »
WOW (again)  Shocked
vwhelmot
« Reply #364 on: April 09, 2018, 14:12:54 pm »
The spindles took some smoothing, they were really rough castings.
I had blasted these when I first restored the car.
Bit of bling
Chromed link pins
vwhelmot
« Reply #365 on: April 11, 2018, 08:35:50 am »
I really enjoyed making up the brake lines and fitting up the pedal assembly.
Fitted up the throttle with its proper hinge
vwhelmot
« Reply #366 on: April 11, 2018, 08:52:44 am »
Steering box
vwhelmot
« Reply #367 on: April 12, 2018, 08:58:40 am »
When it came to the rear suspension I got worried that I would damage paint etc but to be honest it went together smoothly. I machined up some aluminium spacers that fit between the end plate and the adjusters and polished them. The spring plates took two attempts to chrome as I forgot to round off the ends the first time so I sent them back after I modified them .
Gearbox fitting was a two man job
I originally was going to fit a trapeze bar and had done a load of work to mock it up and polish it and smooth all the mountings etc but then had a change of heart because it looked fussy and complicated and I just wanted to try and keep it simple so after these shots I restored and painted up a standard gearbox mount and fitted that instead.
vwhelmot
« Reply #368 on: April 12, 2018, 09:06:32 am »
Rounded spring plate edges
vwhelmot
« Reply #369 on: April 12, 2018, 09:11:00 am »
First parts to go on the body
Seals n stuff
Stainless bolt on release cable tube
sonic
« Reply #370 on: July 22, 2018, 14:41:43 pm »
Top of the line  !!! Smiley
melvin
OFF/83
« Reply #371 on: July 27, 2018, 21:33:07 pm »
nice
 Wink
OFF/83
vwhelmot
« Reply #372 on: November 20, 2018, 09:40:25 am »
Got invited to be part of the Meguiars Showcase at the NEC Classic Car Show earlier this month. Amazing weekend , came home with the prestigious best of show trophy.
brewsy
« Reply #373 on: November 20, 2018, 10:07:04 am »
Youre just showing off now...  Grin Wink
« Reply #374 on: November 20, 2018, 11:10:52 am »
Awesome achievement, well done  Grin
karl h
« Reply #375 on: November 21, 2018, 07:59:05 am »
i can always drool over the pics in your thread, Lyndon......
vwhelmot
« Reply #376 on: November 23, 2018, 08:46:22 am »
Cheers. I must say lifting the car down with a fork lift isn't pleasant
vwhelmot
« Reply #377 on: November 23, 2018, 08:48:34 am »
I think I got the ride height right
Good-Old-Ragtop60
« Reply #378 on: November 23, 2018, 09:36:56 am »
Thank you very much f?r the Pictures! The attention to the details is incredible!
I guess I?ve mentioned before, but I?ve never seen such a high-Level build.
Hats off Sir!  Smiley
