October 14, 2026, 04:52:20 am
AS21 German Crankcase with a Unique roller camshaft setup
Topic: AS21 German Crankcase with a Unique roller camshaft setup (Read 2860 times)
Paul da Graca
June 11, 2015, 20:28:21 pm »
Hello Everyone,
I have a German AS 21 with 8mm case saver, STD on the journals and 22mm on the thrust. Overall a very nice case. HOWEVER, I notice two oil lines on the side of the case and something clicking inside. I open the case and found a roller camshaft setup!!!
With Further investigation, the AS21 case was cleared for a larger crankshaft, but the piston holes are 90mm! Camshaft journals are also STD. on the front where the oil pump goes has longer stud so it had a dry sump setup.
I spoken to Jack from Jaycee and in his 30 year never seen a setup like this. Same from Kris from VW Paradise.
Since I am a street and daily driver motor builder here in Holland, drag motor are not my thing, but I do know how much a setup like this cost. Contact me if you are interest and maybe this could be yours
Last Edit: June 11, 2015, 23:44:53 pm by Paul da Graca
Paul da Graca
Re: AS21 German Crankcase with a Unique roller camshaft setup
June 11, 2015, 20:43:03 pm »
I can send you more photos. Send me a PM and I will email them to you
